Radar Cruise Control Default Distance
Discussion in 'Gen 4 Prius Audio and Electronics' started by 155, Feb 7, 2016.
  1. 155
    155 Member
    56
    30
    Four Touring
    Is there a way to change the default difference on the dynamic radar cruise control from 3 bars to 1 bar?
    I think it's annoying to have to change it everytime that I start the vehicle and activate cruise control.
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Nope, but it remembers that setting till you turn off the system.
    155 likes this.
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    That's an annoyance. How much money did Toyota save by removing that ability from the Gen3?
  4. Mendel Leisk
    41,350
    What are 3 bars and 1? Which is the greater distance?
  5. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The distances are relative, and change with speed.
  6. Tideland Prius
    16,551
    3 bars is greater.
  7. Mendel Leisk
    41,350
    Thanks.
    That's what I suspected, but wasn't clear about. I can see Toyota's point-of-view on this: err on the side of caution.
  8. ETC(SS)
    7,138
    More than you may think.
    Blame the lawyers.
  9. JimN
    7,028
    1,117
    South Jersey
    I believe there is enough blame to spread around. Lawyers, accountants & cheap software contractors come to mind.
  10. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    I am not familiar with the old 1-bar default option, but find it rather natural to start off at 3 bars, then reduce the distance with a click or two of the thumb while driving-- the button to do that is in a good spot.
    Agreed that it is always better to have programming options, though.
  11. Tideland Prius
    16,551
    Yup. Makes sense to me. I usually use 2 bars unless I'm travelling at higher speeds (say 112km/h) or lower speeds (say 50km/h). I use 3 bars at higher speeds and 2 or 1 bars at city speeds.
  12. 155
    155 Member
    56
    30
    Four Touring
    Someone's probably going to correct me on this, but I believe that the distances are as follows:
    1 bar = roughly a 3 second following distance
    2 bars = roughly a 4 second following distance
    3 bars = roughly a 5 second following distance
    The following distance is clearly adaptive as it's a much bigger gap at highway speeds than at city speeds.
    According to Toyota's manual, the car will always physically stop the car at the same distance away from the vehicle in front of you regardless of which bar you are on, so the distance setting doesn't change the distance when stopped.
  13. ATHiker
    644
    560
    Massachusetts
    Four Touring
    Prossibly not on the icy roads I face this morning :).
    On thing I wonder about is when the Radar Cruise is slowing me down, are my brake lights always on?
  14. Tideland Prius
    16,551
    It depends on how hard DRCC is braking.
  15. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    My experience with my gen 3, is that temperature and humidity have a huge effect on the distance.
    Use 2 bars, that way you have +- 1 bar to adjust
