VSC light came on while replacing courtesy light bulb.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius is Best, Feb 6, 2016.
  1. Prius is Best
    Prius is Best New Member
    Virginia
    Hello guys, while I was replacing courtesy light bulb, i got VSC light in my 2010 Prius. It doesn't go off.
    What can be the reason? Any suggestion.
    FYI
    Car was off (while I was replacing bulb)
    Driver side door bulb. Door was open and courtesy light was ON and I removed the bulb while it was in ON position because i did not have any option to turned it off.
    Thank you.
  2. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    Put the old bulb back in
  3. Prius is Best
    Virginia
    I did, but VSC light was still there.
    Thanks
  4. Prius is Best
    Virginia
    Issue solved. Thanks for reading....
  5. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    ...and what did you do to solve the problem?
  6. bisco
    52,286
    probably should have the car off when replacing blubs.
  7. Prius is Best
    Virginia
    When I was replacing bulb, fuse blown up. Fuse # 29 (10A RED) in engine compartment fuse box. I replace it and there is no light anymore.
    Car was OFF but as you know it was courtesy light bulb so when I was replacing it, it was ON. I should have remove negative 12 V cable of it...
    #7 Prius is Best, Feb 8, 2016
