Does the new lightweight tonneau cover work well?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Eric M., Feb 7, 2016.
  1. Tideland Prius
    16,623
    Note that the Four and Four Touring have the roller-style tonneau cover.
  2. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Good to know! thanks :)
    I think a four is the perfect combination of amenities and goodies..(y)
    krmcg likes this.
  3. KenzoTH
    KenzoTH Member
    70
    Rhode Island
    The new 2016 flex nylon cover is flimsy- almost gauze-like. It is attached with black nylon strings to mounting points on the hatch door and mid rear opening where the old scroll type cover hooked (where the cargo net attaches on either side). I know this won't last the 10 + years I mean to keep my 2016.I have a II trim- do upper trims have the "old" style cover?
  4. bisco
    52,404
    hopefully inexpensive if you need to replace it.
  5. Tideland Prius
    16,623
    Four and Four Touring come with the roller-type tonneau cover.
  6. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    Having owned an 04, 08, 12, 13V & now a 16, I can say that both types will keep stuff from popping out and hitting your passengers under normal driving conditions. Likewise, both will fail to contain stuff in the event of an accident. I guess that is why they are called cargo covers, not cargo immobilizers. I happen to prefer the lightweight cover in the 16 Two Eco. It is easy to install, lifts automatically when you open the hatch, and stores easily.
    eric1234 and bisco like this.
  7. bisco
    52,404
    agreed. cargo is something that should be given more thought in a hatchback, in the event of an high speed accident. perhaps the highway safety insurance institute should do some testing.
    Nam Nguyen, DonD and krousdb like this.
  8. artie
    artie Member
    232
    65
    san diego
    I sold my 2004 Prius 2 last month, 293,000 miles, and bought the 2016 3 and I like the flimsy cover a lot, as it is quite convenient, it rises and falls with the lid and removes easily when I needed to put in a large load.
  9. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    The 2016 has 4 fairly robust D-Rings at the 4 corners of the hatch area. I don't recall seeing anything similar in our 2010 but perhaps they are there too.
  10. bisco
    52,404
    i wonder how many people, after filling their hatch with dangerous projectiles, strap them down.
  11. Caniac
    Caniac Active Member
    232
    164
    Happy Valley
    Question to owners of 3T and below....are the cutouts there so you could add a rolling cover if you wanted to buy one later?
    Blizzard_Persona likes this.
  12. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    There are two at the bottom corners of the hatch for the cargo net. Maybe they are also intended to be used to tie down a flat tire.
  13. ATHiker
    644
    560
    Massachusetts
    Four Touring
    There are a total of 4 on the 2016. The second pair are close to where the seat folds-- one on each side a few inches above the floor of the cargo area.
    I expect your theory as to why Toyota saw a need for them may be correct. I hauled a treadmill 500 miles in the back of our 2010 on snowy roads once, and shudder to think what would have happened if we got rear ended.
  14. samdaman
    samdaman Junior Member
    75
    Eastern PA
    For all those having this issue, google for 'folding bandsaw blade' -- lots of videos and text descriptions. Same technique.
  15. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Those are for the spider net. The flat net that stretches to hold cargo down. You just pick the front up and put stuff under it and it holds stuff pretty solid. I had one on all my past Prius and currently have one in my wife's v. It works great.
    Spider Cargo Net for 2010-2015 Toyota Prius - OEM - PriusChat Shop
    Jope, ATHiker and krousdb like this.
  16. Tideland Prius
    16,623
    They're on the Gen 2 and Gen 3.
    Yup. The diagram is in the owner's manual. The idea is that you place the flat wheel in the cargo area and use the tie down straps (included in the car) through one of the spokes of the wheel and hook them onto the D rings. Of course manual assumes you have nothing else in the cargo area.
    Jope likes this.
  17. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    Interesting. In the 2008 manual it shows two straps, each going from front to back on the diagonal, using all four cargo hooks.
  18. Jope
    Jope Junior Member
    Seattle, WA
    Four Touring
    I've looked around for a spider net for the 2016 Prius, I guess it hasn't been made yet, or they're going with the envelope style cargo net in the Shop. I'd like to know if the Gen 3 spider net would work with the Gen 4 cargo area. Anyone have the Gen 3 D-ring dimensions?
  19. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Is should! I took the one out of my Liftback when I traded it in and put it in my wife's v wagon, no issue.
    The Gen4 hatch dimensions can't be that far off compared to Gen3 right?
    #39 Blizzard_Persona, Mar 1, 2016
  20. Jope
    Jope Junior Member
    Seattle, WA
    Four Touring
    Likely not, but I'm a measure twice purchase once kinda guy. ;)
