Donut tire - What/Where to buy for two/four?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Zojja, Feb 6, 2016.
  1. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    Hello,
    I've been thinking about it and I realized that I would like to buy a donut tire for my car. I know I could ask the dealership but I figure there is a cheaper place to buy? My previous car had a full size spare tire so I had just bought one from the tire shop but here, is it the same? Can I go to Costco and buy one?
  2. vince22
    vince22 Active Member
    205
    249
    califorinia
    most likely Ebay ,craigslist and stealership.
  3. Caniac
    Caniac Active Member
    232
    164
    Happy Valley
    I recently spotted a Prius spare for sale on Craigslist so that could be an option too.
  4. bisco
    52,286
    the first thing you need to do is find out if it's the same as gen 3. if it is, you can search the net and salvage yards. if it isn't, you'll have to go with the dealer, or wait for gen 4 wrecks.
    ETP likes this.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    FYI, I've been looking for this since 2012 when I purchased my PiP, also without a spare. I have been unsuccessful.
    It's $106 on tirerack for a Prius-sized tire on a 15" steel rim, a full size spare in other words. Toyota will charge you more for an actual space saver spare. Don't just put it in the trunk because it becomes a dangerous projectile in an accident. Tie it down with something. I want a space saver spare because I don't want to lose the trunk space. I don't want to pay over $100 because full size > space saver. Hence, 3 years later, I have done nothing.
    In the end, I bought another Prius with a spare, so I will just share. (I didn't buy a whole car for a spare tire. It just worked out that way.)
    ETP likes this.
  6. bisco
    52,286
    when i priced a donut at the dealer in 2012, it was $450. complete. i was fortunate that the parts guy had a salvage one he let me have for 50 bucks.
    that's another thought, you can check with the parts departments, some of those guys have connections, if they're not complete idiots.
    they can also give you the wheel spec. a lot of times, there are other toyota models and years that have the same spec. sometimes even other manufacturers like mazda and etc.
    the biggest issue may be the height, since they lowered the floor on the non spare models. but i have no idea really. my donut is about 7" tall, i believe.
    ETP likes this.
  7. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    I looked under my cargo space and it looks like there is room for a tire there, it just isn't there. I wouldn't want to lose cargo space so my plan would be to put a donut spare there if it is possible. I am going to the dealer in a couple days any way so I'll ask and verify that a donut spare would fit there.
    ETP likes this.
  8. Mendel Leisk
    41,826
    At this juncture I'd say just live with what you've got.
    Second option: approach the dealership, see about a swap to a model with spare. This'll obviously cost $'s, but to equip your current model with spare and peripheral pieces, so that it matches a model with spare, will likely cost at least as much, and is an "option" that you likely can't recoup, come trade-in time.
    #8 Mendel Leisk, Feb 6, 2016
    ETP likes this.
  9. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    I watched a video on the patch kit and I think I'll probably just live with it. I've only had to use a spare tire once in my life and it was probably because I wasn't taking care of my tires as well as I should've been.
    ETP likes this.
  10. Mendel Leisk
    41,826
    Maybe look into plug repair kit? Treat the pump and sealant as last resort.
    ETP likes this.
  11. mmmodem
    2,732
    1,703
    Bay Area, CA
    Agreed. Don't use the repair kit unless absolutely necessary. It may damage the TPMS sensor. The person replacing the tire will charge you for cleaning the gunk off the rim. If you lease, you might have to replace with same Toyota repair kit which wouldn't surprise me if it costs more than a spare tire. Costs may be less to be towed to a tire place and put on new tires than driving to a tire place after using repair kit.
    dfine1966 and ETP like this.
  12. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    ok that is good to know. Mine isn't a lease. I mean I figure my chances of having a flat on the side of the road are slim.
    ETP likes this.
  13. 155
    155 Member
    56
    31
    Four Touring
    I received a similar ridiculous quote from a dealer on the 2016. I think they wanted $250 for the tire and $200 for the rim, which is ridiculous considering JustTires quoted me $39 for the tire on the donut on my 2008 the first time I had a flat and was paranoid about needing to replace it (It lasted me several more flats and is still in the car)
    I'm going to replace it, but I'm not really in a rush as I don't think I'll have a problem anytime soon.
    ETP and bisco like this.
  14. gvp1995
    gvp1995 Active Member
    199
    141
    Three Touring
    I am facing exactly the same problem! I want Four Touring but the absence of the spare tire is not a good thing... We travel a lot into national parks and stuff. Mostly no cell phone reception, and I did have a tire damage before, which could not be repaired. Zojja, I understand you already have Four Touring 2016? If so, did you manage to figure out if the donut will fit under the trunk (where it is in Three Touring)? I spoke to one dealer today, and he actually said there is no space. I don't want to go lower to Three Touring because of auto-dimming mirror and HomeLink.
    ETP likes this.
  15. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    I can live without, but I do find it interesting that the spec for the donut looks to be the same whether you have 15" tires or 17" tires. I don't really get that.
    ETP likes this.
  16. bisco
    52,286
    in another thread, krous tore his down, and the donut fit perfectly. just need new styrofoam and a hold down bolt.
    #16 bisco, Feb 10, 2016
    ETP and helmkera like this.
  17. Mendel Leisk
    41,826
    It's ok: same OD, same offset, same bolt pattern, it works.
    That's us btw: 17" OEM and regular temp spare.
    ETP likes this.
  18. gvp1995
    199
    141
    Three Touring
    Yes, but that discussion is about Prius Two with 15" wheels. And in Four Touring it is 17"
    ETP likes this.
  19. mmmodem
    2,732
    1,703
    Bay Area, CA
    You may think 17" wheels are bigger than 15" wheel but the diameter of the wheel (rim plus tire) is the same. Therefore, a spare that works for one will work for the other.
    ETP, wsncguy and Mendel Leisk like this.
  20. bisco
    52,286
    it's a hard concept to grasp. you got 17" wheels, but they're only 15" in diameter?o_O and they cost you a few mpg's? they look good though.(y)
    ETP likes this.
