Went to dealership for Brake fluid flush/bleeding but not sign tires removed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tttran, Feb 8, 2016.
Tags:
  1. tttran
    tttran New Member
    Hello all,
    I just recently got a brake fluid service from Toyota dealership which includes bleeding of the brake fluid. However, when I got back the car I noticed that the tires were virtually untouched. The reason I know this is because the dirt that was no the tires was left without any hand marks.
    My question is, is it possible to bleed the brakes without removing the tires to get to the bleeders?
    Also, it looks like the bracket covering the brake fluid reservoir was untouched as well.
    Does this look
    52,232
    welcome! sounds like you got scammed.:mad: is the fluid the same color as when you brought it in?
  3. Mendel Leisk
    41,786
    I think yes, you can avoid tire removal. Look, see where the bleed screws are, from around the back. Should be possible to see even with car on the ground.
    tttran and sprtent like this.
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    lazy way to flush
    sprtent likes this.
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Why take the wheels off if the bleed screws can be accessed from the inside while the car is on the lift? Also, tubing can be placed over the bleed fittings to neatly drain fluid into a container.
    Dyjital, tttran and sprtent like this.
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Welcome to PriusChat, BTW - also consider that the mechanic at your dealer might have been wearing nitrile gloves! (…no fingerprints! (…heh heh!) :rolleyes: )
    …but be warned! I learned (from one of the lectures at 2GoB4 (2014)) that correctly bleeding the brakes on a Prius can be somewhat difficult for the average DIY-er since it requires specialist equipment and so might be best left to someone with the necessary gear such as the local Toyota dealer. :(
  7. bisco
    52,232
    agreed. o/p should have taken it to a dealer and avoided potential scammation.
  8. xliderider
    8,140
    3,277
    Honolulu, HI
    The OP did take it to the dealer, but felt he got scammed because he didn't see any signs that the wheels where taken off.
    tttran likes this.
  9. bisco
    52,232
    whoops, thanks, i missed that. probably no need for concern then.
  10. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,718
    1,758
    Bay Area
    Yes, its possible to bleed the brakes without removing the wheels. Dealership technicians are on flat rate pay so some of them don't want to waste the time to remove the wheels.
    Better yet, you should do this job yourself. It's too easy not to since you will be saving $$$, here's a video on how to do it. Have fun! :)
    Maroon, kc410, frodoz737 and 3 others like this.
  11. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    What's the recommended interval for a brake fluid flush/service? Is it three years?
  12. bisco
    52,232
    in the u.s., there is no time interval. 120k maybe?
  13. Mendel Leisk
    41,786
    The latest Canadian Schedule I have (2014 Prius) says 48,000 km's (~30,000 miles) or 36 months.
    With our 2010 it was 64,000 km's or 48 months.
    So I guess the current mindset is 30K miles or 3 years.
    FWIW, Honda says every 3 years, regardless of mileage, for quite some time, decades I think.
    sprtent likes this.
  14. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    With a lift, bleeding the brakes is much easier to do without taking off the wheels...but be advised...it's also known that "some" dealers just suck the fluid from the top of the reservoir and refill. This does happen with the Prius because doing it "by the book" takes a while.
  15. sprtent
    sprtent Member
    104
    75
    SF Bay Area
    I would go with 30k-40k or 3 years as well, as mentioned. Also, use the proper DOT#. A higher DOT# isn't always better.
  16. Mendel Leisk
    41,786
    Can even be disastrous I think?
    Safest fluid would be Toyota's, for compatibility.
    I'm inclined to just let the dealership service department do this. Also, ensure they will test drive after, make sure it's ok. I think just asking for this assurance will keep them on their toes.
  17. NutzAboutBolts
    1,718
    1,758
    Bay Area
    I know you can do this service yourself Mendel.
  18. tttran
    tttran New Member
    Wow... thanks for all the advice everyone, its been real educational. I think im going to do this myself next time. I took it to the dealer because i thought you need the techstream software which i do not have or have experience using.
    I still feel a bit iffy about the whole service. Dealership recommended replacing a dirty cabin air filter for $33. And marked my windshield wipers for replacement because they were aftermarket. I only put them on two weeks ago.
  19. tttran
    tttran New Member
    Btw i believe i saw somewhere on the internet that brake fluid service should be done every 60k. However i did mines at 90k.
  20. usnavystgc
    3,159
    990
    Tucson, AZ
    Since we're on this subject, lets talk about why brake fluid needs to be flushed/changed out. I'm convinced that this is a service that doesn't need to be accomplished at all for the following reasons:
    1) Brake fluid is nothing more than hydraulic fluid. What goes bad in the fluid?
    2) There is very little wear since brakes are a closed system. The fluid is simply a medium to transmit force. With regen braking, it transmits very little force and the pistons see way less wear than conventional brake systems (that see very little wear).
    3) Since it is a closed system, there is virtually no opportunity for contamination or water forming from condensation.
    4) I have personally never flushed a brake system and have experienced no problems. Many of my cars have exceeded ten years of service with no brake fluid flush
    Now, can the proponents of this service list the reasons to change it?
