Headlight replacement bulbs for 2012 plugin base
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by dkit, Feb 10, 2016.
  1. dkit
    dkit Junior Member
    27
    Maybe it is searching on a phone but cannot find any useful info on Google: is there a list of the oem and third party bulbs that would fit the plug-in 2012 base model, rather than non plug-in? Thanks in advance.
    #1 dkit, Feb 10, 2016
    52,274
    are you replacing a bad bulb?
  3. dkit
    dkit Junior Member
    27
    Yes. But also looking into upgrading to brighter maybe…
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    H11 is gonna be ur size for the low beam.
    Sylvania H11 SilverStar Ultra High Performance Halogen Headlight Bulbs aregood
    iPhone ?
  5. dkit
    dkit Junior Member
    27
    image.png The reason I am confused about it is that Amazon.com say that such would not be compatible.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Here is a guide
    iPhone ?
  7. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    If you want brighter and a plug n play H11 bulb, get these:
    Philips H11 X-tremeVision
    Amazon sells them or you can probably pick em up at your local Pep Boys for a few bucks more.
    I put these XtremeVision H11 bulbs in my GF's PIP. Much better than the stock H11's and also better than the silver stars.
    You can also run a modded H9 bulb, that's what I use in my PIP, but the XtremeVisions are equally bright and you don't have to mod them to fit an H11 socket.
  8. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    OP, link to an H9 mod thread in a link in my signature below. Look for the video at the end of the thread by mediahound.
