heavy steering wheel
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by armuwaffaque, Feb 13, 2016.
  1. armuwaffaque
    armuwaffaque Junior Member
    25
    sri lanka
    hi experts
    this is not a new problem......it has been there for about 6 months....i own a 3rd gen and i feel the steering bit heavy (actually not soft) to steer compared to other toyota models...the tyre is 215 45 r17.....is it bcause of the tread width of the tyres?....can the steering tightness be adjusted technically at some point....
    thanx in adv
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I can't compare to other Toyota models, but I will say the steering is a little heavier than some other Fords, Nissans and Mazdas that I have driven. Not sure if there is an adjustment or not. Check with your local mechanic.
    Best of luck to you. (y)
  3. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Yes. The steering does feel heavier with the 17's. When we had two Prii, the difference was evident when switching from one, with 15's, to the other...
  4. armuwaffaque
    25
    sri lanka
    Thank you...
    Thank you
    #4 armuwaffaque, Feb 15, 2016
  5. bisco
    52,286
    what pressure are you running the front tyres at?
  6. Mendel Leisk
    41,826
    We've just switched over, from 195/65R15 snow tires, to the OEM 215/45R17's, not a noticeable difference in steering effort. See if a dealership has a 15" loaner/demo you can try, for comparison.
  7. armuwaffaque
    25
    sri lanka
    front 36 psi rear 34 psi ...further i feel my whhel is offcentered...any idea?
    merged
    ok thank you...i will check over...my steering is off centered too....will that be a reason?..
    #7 armuwaffaque, Feb 21, 2016
  8. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    It would not hurt to do a full alignment and check all the suspension components. Off-center steering is not normal.
    frodoz737 likes this.
  9. bisco
    52,286
    has the steering wheel been off center since new?
