07 prius turned 104 K
Discussion in 'Gen 2 Prius Main Forum' started by sean T, Feb 15, 2016.
  1. sean T
    sean T New Member
    CA
    MY 07 prius turned 104K- soon after - many of the warning lights came on red triangle/ ck engine/ needs maintenance- etc. Is this common when the 07 hits 100k?
  2. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Nah, your 12v battery is probably overdue to a change. That usually happens when the 12v is dying.
    WilDavis likes this.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,375
    3,231
    Madison, Wisconsin
    Yep. Super common. All hybrids turn to junk when they hit 100,000 miles.
    It says so in the owners manual.
    All hybrids over 100,000 should just be given to me for free. :)
    Just kidding.......
    Follow Mavi's advice.
  4. sean T
    sean T New Member
    CA
    I think I changed it a year ago.
    I do have a KN filter- that I did not clean the last time my dtr drove it home- she has it now 4 hrs away. I told her to change out filter see if that helps.
  5. sean T
    sean T New Member
    CA
    thanks again for all the input
  6. ericbecky
    4,375
    3,231
    Madison, Wisconsin
    Stop by the local auto parts store.
    They may be able to check your 12v for free.
    You could check it yourself with the "turning lights on/off 3 times while holding the Info button" trick.
    That is a real thing.
    With car in accessory mode (NOT "Ready". In other words keep foot off the brake, press power button.)
    Hold down the "Info" button and while holding it down turn the parking lights on and off 3 times,
    System Check Mode screen comes up
    Press the "Menu" button in the upper right corner
    Diagnosis Menu screen comes up
    Press "Display Check"
    Display Check screen comes up
    Press "Vehicle Signal Check"
    Vehicle Signal Check screen comes up
    The 12v battery voltage will appear in the upper left part of the screen.
    Note the voltage (11.9v - 12.6v is normal)​
    #6 ericbecky, Feb 15, 2016
  7. sean T
    sean T New Member
    CA
    awesome- thanks..again
  8. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Is the MAINT REQ'D light on too? Did it come on at the same time as the others? That's strange since that light is just based on a mileage counter and has nothing to do with the other lights...unless it was already on.
  9. sean T
    sean T New Member
    CA
    Please see image- all these lights went off at the same time:
    just changed filter after lights went on
    ck'd battery- it was 12.5v
    any thoughts
  10. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    If the 12v was at 12.5 volts with the car off, that sounds okay.
    You'll probably want to get the codes read.
  11. sean T
    sean T New Member
    CA
    From what Ive read thru prius chat- it sounds like inverter cooling pump- the car would only go 2mph- so my dtr had to stop - restart the car- then it worked enough to get her home. I'm having it towed to the dealer- I will post the codes once the dealership gives me their analysis.
    Thanks again for the reply
  12. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    You can check inverter coolant pump function...with the car in "ready" mode, have her check for turbulence in the reservoir toward the center, back of the engine compartment with the pink fluid in it. It's sounding more like a significant failure of the traction battery.
    I don't think the inverter coolant pump not working would keep the car from moving. Is the gasoline engine starting? If so, is it running at high speed?
    If it's anywhere near San Fran, you might consider Luscious Garage instead. Luscious Garage | Hybrid Specialists They're kind of the national authority on repairing Prii.
  13. sean T
    sean T New Member
    CA
    The car is in San Marcos- closest dealer is in escondido, CA - See what happens. Thanks again..
  14. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
  15. sean T
    sean T New Member
    CA
    Drum roll Please: codes from technician
    P0A80
    P3021 x 2 both show hybrid battery weak/
    so the dealership will replace the battery - since it is still under warranty-
    they noticed drive belt was cracked - so they will replace the belt
    thanks again for all input and info.
    tanglefoot likes this.
  16. ericbecky
    4,375
    3,231
    Madison, Wisconsin
    If I were you, at the least I would get Torque app so you can do your own code reading in the future.
  17. sean T
    sean T New Member
    CA
    Thanks for the recommendation
  18. sean T
    sean T New Member
    CA
    Battery was replaced- but not without some hesitation from the dealership where the car is being serviced - I had inverter recall completed- nothing to the battery- the service dept stated that they could not warranty to battery because of the work that had been done to the battery. I didnt have any work done to the battery. I had the dealership call that has done 100% of all the work until this incident. I then rec'd a call stating the car was ready- not sure what was discussed- but the service dept called and stated that the warranty work was Ok'd- not sure by who. So, hybrid battery was replaced thru warranty / drive belt replaced due to wear.
  19. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    The 12V AuxBattery in my 2009 Gen II up and died at about a year ago (~ 106,000miles). First symptoms were SKS system started to get flakey and not resolved by replacing fob batteries. Eventually I had to use JumpStart system so I had the dealer to a load test, they found dying AuxBattery which they changed, and so problem was fixed. I've started using a battery-maintainer (Sears DieHard) - I connected the pig-tail to the jump-points under the hood, so now if the car is not going to be used for a few days, I can quickly plug in the maintainer, and make sure the AuxBattery is kept in good shape! hope this helps - Wil :)
