Battery bars are green then blue then green
Discussion in 'Gen 2 Prius Main Forum' started by Freedom, Feb 20, 2016.
  1. Freedom
    Freedom Active Member
    540
    73
    Northeastern MA
    Carmine sat in my garage for 5 weeks; I've had a left total knee replacement. Today I went out and was able to get IN the car. Started right up so I went for a drive. FREEDOM!
    I notice the bars for the battery are green. Normally they are blue and remain blue. Went on the highway, did about 20 miles. Eventually the bars turned blue. Some time later I glanced again, they were green again. As the photos attached show, when they are blue, they are one stripe lower.
    Went home, got my dogs in and took them to the field. Once we returned to the car to drive home, same thing. It started green, eventually went to blue, next time I looked it was green again.
    Any ideas what is going on? And should I be driving it on the highway more or the city roads more to correct this?
    52,390
    correct, this has always been the case. green near the top, blue through the middle, and purple near the bottom. are you still on the pain meds?:p
    kenoarto likes this.
  3. Tideland Prius
    16,621
    The colour is just for reference and to make it easy to denote how much charge you have in the battery. The battery display is segmented into 8.
    Green = 7 to 8 bars
    Blue = 3 to 6 bars
    Pink/Purple = 1 to 2 bars
    You don't need to do anything. It's functioning as intended. The battery likes to sit at 6 bars (remember that the display isn't showing the actual battery state of charge but rather than range that Toyota programs the battery to stay within). The buffer of 7 and 8 bars is just in case you go down a hill or regenerate really well and it's used to top off the battery (instead of using your brake pads).
  4. Freedom
    540
    73
    Northeastern MA
    Sorry, never been the case on Carmine. Always been BLUE. Did you look at the photos, Bisco?
    I stopped the prescription meds yesterday morning, so they've been out of my system for 24 hours; hence my foray ha haaa. Still using Tylenol Extra Strength and Motrin. Not approved to drive yet, still have inhome services. Just HAD to get OUT of this house!
  5. Freedom
    540
    73
    Northeastern MA
    Tideland, well, OK then. But in 8 years, I've never seen it green like that! But with both Bisco and you telling me it is OK, I guess I won't worry. Thanks both of you.
  6. Tideland Prius
    16,621
    John's Stuff - Toyota Prius and more
    It's strictly for ease of reference. The Gen 3 went back to monochrome so you have to count the bars yourself or estimate. I like the full colour. It provides high glance value.
    Data Daedalus likes this.
  7. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Glad to hear you're recovering well. I'd really like to think your never seeing green on the charging graphic of your MFD is the exception to the norm (compared to most of us, I'd wager), but it's by no means indicative of a problem.
    I notice that if I have a lot of electrical systems running on board, like demisters, wipers, climate control, GPS, Premium JBL audio et al, I also never go up to green. However, most days on my commute, I'm liable to attain green status; twice on the way to work in the mornings (18 mile one way commute) and usually the same on the way back, unless I encounter heavy traffic. In very heavy traffic caused by major roadworks, I'll even drop to purple bars - usually while crawling through a 1.5 mile 3 lane "mother of all traffic jams" (I'm looking at you, A406 between Brent Cross & IKEA Neasden...!!).
    With regards to your Prius, as they say on Star Trek, "All systems are working within design parameters" :)
    iPhone 6s +
  8. Freedom
    540
    73
    Northeastern MA
    Ha ha haa, ok, ok I get it! Green and blue are normal! I really don't recall seeing the green in 8 years of ownership.
  9. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    We get this question in winter.
    I am often in the "green" in winter as the cabin heat runs the ICE engine which helps to charge the batt. If you want to see more blue, wait until summer with A/C running to cool off car.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Big swings from fully charged to low charge usually indicate a failing hybrid battery. I hope so because you may be still in warranty which is 8/100,000 miles. if less than 100K miles you may get a free new battery soon. What's the miles and what date did you buy the car new?
    jeff652 likes this.
  11. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    No need for concern until you're oscillating between green and purple.
  12. hill
    8,924
    I'd make a joke about how many times we've answered this - trailing with "the search tool can be your friend" ... but I'll refrain
    yea, for some of us ocd types, it may be better to just turn the screen off - but that may lead to another often repeated asked & answered series of questions.
    (y)
  13. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    Purple is normal too, not just green and blue. If you ever notice that it's purple, don't freak out. It doesn't mean your car is about to die. It just means the ICE is about the kick on to boost the state of charge.
  14. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Yup. If you are in warranty and it fails get the free battery. If you are close to the warranty expiring and your not going to get a free replacement, consider maintaining the battery with our Prolong Battery systems. Most people ignore battery maintenance until it is too late and end up having to replace at their own expense.
