Eco Indicator Light Always Off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chathud, Feb 19, 2016.
  1. chathud
    chathud New Member
    srilanka
    I got the check hybird system warning message and then i reset the indicator by turning off/ on the car for 3 times in a row.
    Now I noticed the Eco light never came on, even though I was in ECO mode and was most often driving outside the power zone.
    Any idea on this?
  2. qdllc
    qdllc Senior Member
    1,376
    400
    What happens when you press the "Eco" button?
    Are you talking the Eco mode indicator on the MFD or the green ECO mode light above the speedometer?
  3. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    Good question. Toyota confuses us by using the "ECO" term for those two separate meanings, and now to make matters worse, "ECO" has become a trim version as well. Enough of ECO!
  4. chathud
    chathud New Member
    srilanka
  5. bisco
    51,884
    maybe try disconnecting the 12v. btw, is the 12v health okay?
    chathud likes this.
  6. chathud
    chathud New Member
    srilanka
    This works fine.i got my eco light back.
  7. Mendel Leisk
    41,389
    The car needs a "reboot" button.
  8. yeldogt
    yeldogt Active Member
    810
    313
    NE
    You can turn the "eco" light on and off -- I think it may be in the setting menu..
  9. qdllc
    qdllc Senior Member
    1,376
    400
    If Microsoft made cars.... :unsure:
  10. chathud
    chathud New Member
    srilanka
    Oooh then there will be blue screens on the hybrid indicater screen too. LOL
