Real World MPG Numbers
Discussion in 'Gen 4 Prius Fuel Economy' started by krmcg, Jan 22, 2016.
  1. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    On my 2012 Prius v the MPG for total miles driven would reset when I pressed update on the PAST HISTORY screen (PAST HISTORY screen attached below.)
    Could this explain the bouncing MPG for total miles driven?
    ATHiker likes this.
  2. bwilson4web
    16,332
    Hey new owners, please consider putting your mileage up on:
    Fuelly.com com is also good but the EPA site gets a lot of visitors who aren't us. <GRINS>
  3. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Same in Spritmonitor.de, I saw yesterday, there is only one 4gen Prius registered...
  4. dropshot94
    dropshot94 Junior Member
    Colorado Springs, CO
    I'm already on there.
    iPhone ?
  5. krmcg
    2,592
    2,392
    Whittier, CA
    Joined!
    Blizzard_Persona likes this.
  6. akhare
    akhare Member
    47
    53
    Joined too...averaging 54.1 mph (first fill) with the P4 in hilly conditions and 40-50 F weather in Portland, OR. Best was ~70 mpg on a 30 mile round trip (mostly freeway), and it seems to be settling down into the high 50s - 60s in the past week or so.
  7. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    I have seen many comments about the MFD optimism, but has anyone ever checked the odometer accuracy? The testing the Wayne Gerdes did on a prototype Two Eco has been mentioned a few times here with the take away being that the MFD was dead on. But if you look at his calculations, it shows that the odometer under reported by 2.1% while the MFD over reported by 1.6% IIRC. The differences largely balanced out to what has been reported as dead on.
    I noticed this also on my production Two Eco as well. The commute that I have been making in my Gen 2 and Gen 3 for 9 years always ended up around 130 miles round trip for 9 years. But now with the Gen 4, it is 125.0 miles.
    Wayne Gerdes used a garmin to check distance. Since I don't have a garmin, I used Google maps to painstakingly plot the round trip commute. Google maps says it is 128.1 miles or 2.5% higher than what my odometer shows. I wonder if Fuelly lets you compensate for odometer inaccuracy of do you just have to calculate and add the miles manually?
    Anyway, that result is with the Bridgestone Ecopia 422 plus 195/65/15 89S. What could you expect from the 17's? Based on the N/V ratio data in the EPA test files, the 17's are 20.1 and the 15's are 20.0. So 20.0/20.1= 97.5%. So compared to the 15's, the 17's register 2.5% fewer miles. Theoretically, that would make the ODO dead on with 17's.
    It would be interesting if others reported on odometer accuracy as well. Just to verity my results.
    bwilson4web and telmo744 like this.
  8. tzx4
    tzx4 Active Member
    164
    148
    On a British website, they reported that in their government's certifications, the 17 inch wheels generate 83grams/kilometer of CO2 vs 70 for the 15 inchers. Toyota offers the 15 inches on all trim levels in order to bypass some sort of regulation or fee to drive said vehicle in London.
    My suspicion is that here in the USA Toyota certified a mix of both tire types to get the 52mpg rating. They certified the 2 ECO with 15 inch tires and higher specified tire pressure to get the 56 overall mpg.
    #148 tzx4, Feb 29, 2016
  9. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
  10. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    First refuel.
    Drove 586 miles, then fuel light came on. Put in 10.3 gallons.
    Dashboard display says I was averaging 60.5 mpg.
    My hand calculation says I got 56.8 mpg.
    So I will assume the dash display overstates the mileage by about 4 mpg.
    That's fine. 56 is wonderful.
    I pretty much just drive it like a regular car.
    #150 Coast Cruiser, Mar 20, 2016
    krmcg likes this.
  11. inferno
    inferno Senior Member
    1,072
    405
    Which car? Eco or regular?
  12. Coast Cruiser
    2,267
    2,571
    inferno, I have the regular 2016 Three model. I chose the Three model because I wanted a spare tire, and the new Lithium-Ion battery.
    I drive in "Eco" mode and "Normal" mode. Don't notice much difference.
    I haven't tried "Power" yet. Don't think I will need it.
    I'm perfectly happy with 56 mpg. My '05 Camry SE with the V6 engine was only getting about 17 mpg around the city.
    krousdb likes this.
  13. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    If you have 15" wheels, your odometer is probably under reporting by about 2%. So you actually drove 597 miles and you are at 58 MPG. Bonus!
  14. Coast Cruiser
    2,267
    2,571
    krousdb, that's interesting. How did you come about that information? Did you see test data somewhere?
    I don't trust the fuel mileage figure that is shown after making short trips; 25, 50, 100 miles. I was in the 80s after some of those short drives!
    I wanted to see the mpg after going through a full tank. And I got 56. After driving that gas-guzzling Camry for 11 years, I'd be happy with just getting 40 mpg!
    (Yes, my Three model comes with the 15" wheels, same as your Two. And I have Toyo tires.)
    #154 Coast Cruiser, Mar 20, 2016
  15. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    I have verified the Odometer discrepancy using google maps (three times) and others have used a Gps to get similar results. Those that have the 17" wheels should be over reporting by about 0.5 %.
  16. Coast Cruiser
    2,267
    2,571
    I drove around this morning and kept the car 100% in the "Normal" mode. It actually drives easier (compared to "Eco") performs better, and the gas mileage didn't suffer at all.
    No more "Eco" for me. I'll leave that to all you old Hippies. :ROFLMAO:
    #156 Coast Cruiser, Mar 21, 2016
    vince22 likes this.
  17. krmcg
    2,592
    2,392
    Whittier, CA
    Another trip to the gas station...
    First Fill-up 650
    Odometer 650
    Gallons (first click) 10.211
    Calculated MPG 63.66
    MFD display MPG 64.9
    MPG Delta -1.95%
    Gas Light Notification 616
    DTE Reached "Zero" 637
    2nd 675
    Odometer 1325
    Gallons (first click) 10.605
    Calculated MPG 63.65
    MFD display MPG 67.9
    MPG Delta -6.68%
    Gas Light Notification 610
    DTE Reached "Zero" 650
    3rd
    725
    Odometer 2050
    Gallons (first click) 10.571
    Calculated MPG 68.58
    MFD display MPG 72.4
    MPG Delta -5.57%
    Gas Light Notification 666
    DTE Reached "Zero" 700
    4th
    671
    Odometer 2721
    Gallons (first click) 10.164
    Calculated MPG 66.02
    MFD display MPG 69.5
    MPG Delta -5.27%
    Gas Light Notification 640
    DTE Reached "Zero" 665
    5th
    728
    Odometer 3449
    Gallons (first click) 10.935
    Calculated MPG 66.58
    MFD display MPG 69.2
    MPG Delta -3.94%
    All-up data:
    Odometer 3449
    Gallons (first click) 52.5
    Calculated MPG 65.71
    MFD display MPG 68.8 average
    MPG Delta -4.68% average
    Gas Light Notification 634.4 average
    DTE Reached "Zero" 663.4 average
    Bay Stater, altdel, Sergiospl and 3 others like this.
  18. bwilson4web
    16,332
    Funnily enough the EPA testers had the largest error using 'Eco' versus normal or power.
  19. vince22
    vince22 Active Member
    205
    249
    califorinia
    I like this combo, Normal mode (city) Eco mode (freeway) works great.
  20. tzx4
    tzx4 Active Member
    164
    148
    So far, three fill-ups in my Two Eco. The MFD has been 1.5%, 2.4%, and 1.1% higher than the good ol' odometer, pencil, paper, and calculator method.
