Please help me with these freaking rattles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hamocidal, Feb 25, 2016.
  1. hamocidal
    hamocidal New Member
    Rotterdam, The Netherlands
    Dear Prius drivers,
    I really hope you can help me out. Ive already red alot about this problem, but I was hoping you could explain to me in a more specific way, if possible with pictures.
    As you can read in the thread title I'am going nuts because of interior noises. I have owned much cheaper cars with lesser quality interiors that didnt rattle this much. I'm really disapointed.
    So i have a few rattles I hope you can help me out with. I recently purchased a 2010 Prius with about 117k KM (about 70k miles).
    The rattles in the interior i have are the following
    - The most anoying one is the rattle coming from the drivers side door (LHD), about at the hight of the seatbelt. I noticed that i cant hear the rattle when i roll down the window a bit.
    - The second most anoying rattle is coming from the corner of the passengers side dash. When the car is accelerating and making certain frequency vibration, i can hear a buzzing rattle coming from the passengersside of the dash.
    - I tapped on the speakercover and i can hear some tickin sound, which i think i can hear as well when im driving on rough roads.
    The roads in the Netherlands are almost all made from bricks, except for main roads and highways. So try to imagine how annoying this is.
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    It is not difficult to remove the door panels and the dashboard speaker covers. Doing so should help you identify and fix the sources of the rattles. I am planning on putting speakers in my doors this weekend. I can take some photos if you wish.
    hamocidal likes this.
  3. hamocidal
    Thanks, I think i will stuff the whole door panel and inside of the door with sound deadning and foam pads to prevent any form of resonation or cables banging on the panels. Is it hard to remove the door panels?
  4. Rebound
    3,996
    2,645
    Portland, OR
    I will let you know after I do it. I've removed the dash speaker cover and it's pretty easy. You need to remove the A-arm pillar first. I will post some illustrations when I'm back at my desk.
  5. hamocidal
    Thank you so much. For your info, this is what regular roads look like hear. The prius is raping my ears.
  6. Rebound
    3,996
    2,645
    Portland, OR
    Holland is so beautiful... it's my favorite country to visit.
  7. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    Your "second most" sounds like this one
    Rattle or Buzz on Passenger Side? Check Here: | Page 2 | PriusChat
  8. sprtent
    sprtent Member
    104
    75
    SF Bay Area
    Given the Prius is built for what it is and without much attention given to interior noise/rattle comfort, along with looking for ways to cure those rattling areas, I would look to see if it's possible to make the car less vibrate to begin with driving on brick roads.
    Quality of tires and tire pressure come to mind. We own Prii because of high MPG, but in this case I would sacrify a couple MPG for a better riding comfort. I would decrease tire pressure to a minimum acceptable level. If and when it's time to replace tires, I would look for tires that are more quiet/comfort and softer, versus handling, best mpg, etc.
    Removing door panels are not hard at all. One screw inside the small cover of the door level. Another small screw on the bottom of the door handle "pocket", underneath the black rubber piece . Then pull the panel out, starting from bottom, then lift it up. There are small, black, soft, rubber/paper-like washers on those door-panel push-pins. Make sure you don't loose them.
  9. hamocidal
    Thank you for your assistance, really appriciate it.
    I think i will remove the door panels so i can stick some dynamat / resonation killers on the the door itself (inside) so at least some vibrations will be killed. I will put some soft foam on the door (between door and door panel), ill make sure the cables for the door/lock mechanism and elctric whiring are threaded trough the foam pad so they wont get blocked and/or have a hard surface to resonate on.
    Ill post some pics and results.
  10. Rebound
    3,996
    2,645
    Portland, OR
    While installing new dashboard speakers today, I found something interesting: When you remove the A-pillar cover, there's a cover beneath the small triangular window. This piece is vented to let the defroster warm the glass. Remove this piece, and beneath is a small plastic "cup." Mine had something inside. Presumably, something fell inside the vent, landed in this little cup, and it's been rattling away for years. I shook it out, now that rattle is gone.
    In the photo below, it's the small tan piece of plastic with the five slots.
  11. Topp Cat
    Topp Cat Member
    71
    66
    I have a 2015 Prius first thing I notice there are layers upon layers of rattles I spend estimating over 100+ hrs securing& sound proofing it! One common rattle where u can't do anything about it is the seat belt retractor. it's a motion ball that re acts to movement to lock the seat belt. I suggest to tighten all panels and wedge foam window seal strips between suspected areas of rattles to isolate problem.
  12. CR94
    CR94 Senior Member
    2,751
    1,205
    Northwestern S.C.
    Mine has a very annoying rattle at the connection between the rear of the flying buttress and the lower part of the center console. If I pull on the flying buttress, the rattle stops, temporarily. Anybody know how to tighten up that junction? I'm hoping there's a hidden nut or bolt that needs tightening, if I learn how to uncover it. Thanks!
  13. hamocidal
    Thanks for the info man, will have a look at it. I solved most of the rattles. The interior rattles that i still have are casued by the fact that the materials used are made from recycled dildos. Next thing to do is tighten all bottom plating, but ill do it with the next oil change as the car will be on a ramp anyways.
  14. Rebound
    3,996
    2,645
    Portland, OR
    If you want to know, it's cellulose fiber from exotic trees which are renewable farmed to provide a non-petroleum-based material.
    The biggest source of rattle in my 2010 Prius was the spare tire, which sits on a piece of styrofoam. I bought some cheap felt at a fabric store and wrapped the tire in the felt.
  15. Mendel Leisk
    41,908
    I'm surprised the car isn't made out of bricks, lol. Goeie dag!
    Rebound likes this.
  16. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    100_1852.JPG 100_1853.JPG 100_1854.JPG 100_1855.JPG 100_1856.JPG 100_1857.JPG 100_1851.JPG I recently helped a friend with some serious dash rattle issues. We tore down the dash and found these areas to cause squeaks, ticking and rattles under the dash-plate. They were hard to discover until we drove his Prius on some rough roads with the dash-plate off. Here are some pictures showing all the culprit areas. We solved it with lots of pieces of foam rubber tucked behind the intersections of plastic ducting and the electrical connectors attached to the central crash support tube structure.
  17. Rebound
    3,996
    2,645
    Portland, OR
    I'll mail you a beer if you tell us how you removed the dash. I know how to remove the glove box and the A-arm pillar plastic, but the top of the dash... how do I remove that?
  18. phoenixgreg
    1,157
    295
    66
    Phoenix
    No need for a beer, but thanks anyway. I'll come up with a step by step writeup (sorry no additional pictures) and post here later. This is advanced trim removal and if the connections on your car are stubborn, there's always a chance for marring or clip breakage. Give yourself a day to do this. More later when I complete the writeup.
    UPDATE: I'm doing this same process to another Prius next weekend and will get pictures of the removal process of the dash-plate.
    #18 phoenixgreg, Mar 20, 2016
  19. Topp Cat
    Topp Cat Member
    71
    66
    Haha this show how cheaply Prius are put together! 2 dollars worth of insulation would prevent these but in term that 7 million dollar more in profits. Please do post info to remove dash! Iam sure I will do this some day! Many Thanks!
    phoenixgreg likes this.
  20. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Please post a write up!!! I definitely need it because I'm thinking about getting two bird with one stone with the auto headlight mod and insulating the dash components.
