Gas engine not cycling on properly
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Psi296, May 12, 2006.
  1. Psi296
    Psi296 New Member
    Baton Rouge, LA
    It also won't stay on when you let off the gas pedal while in park. It revs up but then shuts off quickly. THis cause my battery to run down to 2 bars and the gas engine still won't engage.
    Has anyone heard about this?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Sounds like it's working fine. It's not supposed to come on unless the battery charge drops very low (1-2 bars depending upon whether the heat/AC is on etc.) or you're actually driving.
    This is a good thing, burning gas when you're not moving is wasteful.
  3. Psi296
    Psi296 New Member
    Baton Rouge, LA
    But when the ICE does engage, it immediately shuts back off without even attempting to charge the battery...basically if I don't press and hold the gas pedal, the gas engine will not engage.
    That can't be right.
  4. ghostofjk
    ghostofjk New Member
    979
    No, with two bars showing on the HV battery, something's not right. How many miles have you driven it?
  5. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Psi296 @ May 12 2006, 08:01 PM) [snapback]254459[/snapback]</div>
    It is right. There is no reason it should/would "charge up" the HV battery. The ICE will run briefly to reestablish a reasonable SOC (1-2 bars) then shut off again in anticipation that you will start driving again soon. At that point it will engage its normal algorythms and get the SOC back up in the 4-6 bar range.
    Don't get caught in the trap of thinking that the battery 'needs' to be at a certain SOC.
    Your car is working fine. My suggestion to you is to avoid situations where you're just sitting with the car in READY mode and not moving or going anywhere.
    <div class='quotetop'>QUOTE(ghostofjk @ May 12 2006, 08:09 PM) [snapback]254463[/snapback]</div>
    Sorry, I think you're mistaken. If it only stayed at 2 bars even with normal driving I might agree, but he's talking about when the car is sitting going nowhere. The battery will, in those cases, drain down to 1-2 bars and go through the very brief ICE run, then shut down sequences until you get moving again and the SOC will not often go above 2 bars...I've rarely seen 3 in those occasions, but usually just 1-2.
  6. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(efusco @ May 12 2006, 06:51 PM) [snapback]254483[/snapback]</div>
    Agreed! This is how it works by design, folks. Don't fight it. Be happy.
    If you really WANT that ICE running all the time, you've purchased the wrong vehicle.
  7. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Some others have reported similar experiences. Some while driving, others while parked. I usually shrug it off as the car being indecisive (not technical, but people can understand it).
    It's as though the car says, "my battery is low so I'll run the ICE but I'm not moving, so I'll turn it off but it's a bit chilly so I better turn on to heat up but we're in park so I'll turn off but the battery's low so I'll turn on..."
    After almost two years of driving my Prius, I am certain that there's nothing wrong with your car. I have more of an issue with your car having only two bars remaining. Just how often do you have that situation and what are you doing to get to that state?
  8. qbee42
    3,080
    Evan and Darell have it right. Your ICE is doing exactly what is supposed to do under those conditions. There is absolutely no reason it should charge the traction battery while you are just sitting there, unless the SOC gets very low.
  9. Psi296
    Psi296 New Member
    Baton Rouge, LA
    Thanks for the responses guys.
    In response to your questions, I have 4700 miles on the car. Even though traffic here in Baton Rouge is usually a nightmare...I have never experienced the battery getting that low...or just haven't noticed it if it has.
    Today was unusual, it was very hot so the A/C was on full and I was stuck in standstill traffic due to an accident, so I was just sitting there and noticed that only 2 bars on the battery were left and the ICE was doing nothing and I guess I just panicked.
    Anyway, I am bringing the car in to have the oil changed tomorrow and they said they would take a look and see if anything is amiss.
    Thanks again for the information, this site has once again proven to be a lifesaver.
  10. ghostofjk
    979
    I've had four Priuses and have driven a total of about 125K mi. in them. I've never seen a SOC under 3 bars, under any conditions. In fact, I think I remember Graham or someone saying the system would not allow the SOC to go below 3-4 bars, with the possible exception of limping toward a gas station having run out of gas. I suppose in an extreme case (AC on, gridlock) I can imagine it GOING down to 2 bars, but I can't imagine that not causing the ICE to cycle on. And I've been stuck in gridlock with the AC on several times.
  11. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(ghostofjk @ May 13 2006, 01:23 AM) [snapback]254637[/snapback]</div>
    I don't know what to tell you...It is normal, it is not uncommon for me to see 2 bars (not common either, but the circumstances are predictible enough). Most recently waiting in line at a Chinese restraunt about a month ago with almost identical circumstances. Just before that I made 3 sub-1/4mi. drives/starts in a row and dropped to 2 bars.
    Gridlock with AC has done it as well and it behaved exactly as the OP described.
    Also, he said the ICE DID cycle on, but only briefly.
    The situation he described is normal for me and at least 3 others have concurred here....why you haven't experienced it I can't explain, but I think your circumstance is more unusual than those of us who've seen 1-2 bars.
  12. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    I suppose I'll jump in now and also state that what has been seen is totally normal. The charge-level will indeed drop down to pink (2 bars) then only do the minimum to maintain rather than recharge to recover. Not seeing that behavior would actually be rather odd.
    JUST DRIVE IT!
    It's amazing how that tried & true advice for so many years ago still works today. Don't get hung up on what it decides to do. Some owners even unknowingly penalize themselves by trying to outsmart the system, ending up with lower MPG than if they had just ignored what the Multi-Display. It's far to easy to get hung up in the moment, causing you to forget the big picture.
    Focus on overall efficiency. Don't be concerned when the charge-level or the consumption-bar dips below a threshold you assume is bad, because most of the time that perception is incorrect. You need to base performance on a range of time, not just immediate feedback.
  13. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    sounds like a case of too much info to worry about. the car can handle itself, and i'll testify to the AC in slow moving traffic dropping you down to 1 bar. the engine will kick on as needed to maintain any charge above the minimum threshhold, but any more is wasteful. why waste? be happy the gas engine is off :D
    standing with one foot on the brake and one foot on the gas is probably not good for the generators.
  14. efusco
    19,891
    1,196
    Nixa, MO
    LOL, seeing Gal's post it reminded me of the single most common time that I've seen 1-2 bars....when I've had to have the car serviced! Almost every time it's required something more than just an oil change I get the car back with 1-2 pink bars and just shake my head wondering what they were doing to my 'baby' back there in the shop.
  15. galaxee
    9,810
    471
    MD
    evan- they leave the ignition on and listen to the radio, i'm willing to bet.
  16. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    <div class='quotetop'>QUOTE(Psi296 @ May 12 2006, 10:20 PM) [snapback]254545[/snapback]</div>
    Yeah, don't worry a thing about it. I evacuated Houston for Hurricane Rita in my '05 on an extremely hot day and had the AC running. There were times, sitting in that gridlock, where simply taking my foot off the brake to creep forward three feet would cause the ICE to come on -- didn't even have to touch the accelerator -- because the battery was low.
    It doesn't damage the car at all -- it knows what it's doing.
