2016 Prius Lower Console/Shifter Appliqué Package
Discussion in 'Gen 4 Prius Accessories and Modifications' started by NorCaGuy, Feb 9, 2016.
  1. NorCaGuy
    NorCaGuy Junior Member
    Chico CA
    Four Touring
    Has anyone purchased the 2016 Prius Lower Console/Shifter Applique Package that is for sale in the Prius Accessory shop? The photo looks great but I was wondering about the quality of the product and if it is really worth the $$$. I was okay with the bone white china look until one of my friends (a non Prius owner) said it looked like a urinal.
    #1 NorCaGuy, Feb 9, 2016
    m.wynn likes this.
    52,286
    don't listen to friends, they'll end up costing you a lot of money.:p
    Sommer86, Fobbers, Tyfly and 5 others like this.
  3. nyprius
    nyprius Member
    385
    24
    Saratoga Springs, NY
    Your friend was right. Toyota is great, as I'm sure the Gen 4 is. But they make mistakes sometimes. The white console does look like a toilet. It's a really bad idea. Every drop of coffee or anything else will show on it. Maybe the intention was to make the car look clean. But this will make it look dirty.
    Also, the white seats on some models seem lame. They'll also show dirt and stains easily. I won't buy a Gen 4 until next year. Hopefully by then Toyota will have put the lid down on the toilet (i.e. get rid of the ridiculous white console, seats and other highlights). I can just imagine a kid with dirty hands in the front seat, or a dog. The white is going to look real bad real fast.
  4. krmcg
    2,592
    2,392
    Whittier, CA
    Yes. Looks good. High quality.
  5. Timmins13
    Timmins13 New Member
    17
    Washington State
    Still waiting on my car. I'm wondering, can I apply the applique package myself? Or is it something the dealer or a shop needs to do because of the difficulty installing it? Are there directions that can be found on the internet or a YouTube video on how to install the covering? Thanks.
  6. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Be sure a clean the surfaces first. I used an alcohol wipe. Make sure it drys.
    The tricky part is making sure the lower pieces clears the cigarette lighter cover-door and the usb cover-door.
    So without seating it, push it back as far as it goes and lower the back portion first.
    Verify that the little doors can open and shut freely before you lower the rest of the cover into contact.
    You won't be able to shift the cover once comes into full contact.
  7. Timmins13
    17
    Washington State
    Thanks for the installation advice.
  8. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    The instructions tell you to not unplug anything to install the cover. I unplugged everything and even removed the cup holders. This made it much easier to work with. [​IMG]
    Just remember to plug everything back in when you're done!!
    CoolPrius, Fobbers, Jim in NC and 2 others like this.
  9. DavidA
    2,345
    1,821
    Chicago western burbs
    ^ Good photos. Thanks for your informative post!
    wenreder and Plus IV like this.
  10. wenreder
    wenreder Junior Member
    Cypress Lakes Lakeland, Fl 33810
    Is the 2016 PRIUS LOWER CONSOLE/SHIFTER APPLIQUÉ PACKAGE available anywhere else for less than $299 ??
  11. krmcg
    2,592
    2,392
    Whittier, CA
    Look on eBay
  12. Eric Saxe
    Eric Saxe New Member
    Spring Hill, TN
    I have the black that came from the dealer installed and it looks great for what its worth. It also seems well built and integrated to the original.
    Regards,
    Eric
  13. Oversplode
    Oversplode Member
    58
    72
    Was it hard to pull that off? It looks like it makes installing the applique a lot easier!
  14. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    No, it wasn't hard at all. Just a gentle tug to release the clips. Then unplug everything, unscrew the cup holder, and you're ready.
    wenreder and Oversplode like this.
  15. JMFB
    JMFB New Member
    22
    KC
    Four Touring
    I just picked up my Prius 4 Touring yesterday. It came with the Lower Console/Shifter Appliqué Package. I have an Iphone 6 Plus and noticed that the phone will not lay flat on the Qi charging pad because of the Lower console Applique. Do you know how it is secured to the console? Is it easy to get it off?
  16. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    The kit is with double sided sticky tape.
    JMFB likes this.
  17. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    The iPhone 6 Plus will not fit in that area, even without the appliqué.
  18. krmcg
    2,592
    2,392
    Whittier, CA
    Yes, double stick tape. Will probably ruin it to remove it, but should not hurt the white surface at all. Just get some goop-off to clean it up.
    vince22 and JMFB like this.
  19. JMFB
    JMFB New Member
    22
    KC
    Four Touring
    Bummer. Glad I asked before I ripped the applique off.
  20. PeterKG
    PeterKG Member
    62
    79
    Playa Vista, CA
    Four Touring
    I'm not happy with my appliqué. It's already coming loose. It also isn't the same metallic black as the console and the shifter appliqué. I might remove it too.
    Be careful with Goof Off or Goo Gone not to get it on Softex seats if you have them. I did on my 2015 PIP and have a shinny forever stain/spot.
    #20 PeterKG, Mar 15, 2016
    krmcg likes this.
