38 mpg
Discussion in 'Gen 2 Prius Fuel Economy' started by ddegip, Feb 27, 2016.
Tags:
  1. ddegip
    ddegip Junior Member
    PR
    I have a 2005 Prius (145k miles) with new original battery and computer, new tires (original size) but I average 38 mpg. Any tips for me to increase that number?
    52,407
    welcome! sure, there are so many things to look into.
    start with he tyres. what brand and specs? they can make a huge mpg impact.
    next, check your 12 volt health.
    third, what is your commute like? round trip miles, how aggressively do you drive? topography?
    then, let's hear more about this new battery. who installed it?
    finally, tell us about maintenance history. is it up to date? what do you know? how are the brakes? anything dragging? spark plugs? injection system? throttle body and maf? pcv valve?
    when we get past all the basic stuff, we'll talk about pulse and glide and other hypermiling techniques. but first, you need to find out what's wrong with your car. all the best!(y)
    #2 bisco, Feb 27, 2016
  3. wjtracy
    wjtracy Senior Member
    11,372
    3,609
    Northern VA (NoVA)
    Winter is bad news. Short commutes are bad news, as it takes about 10-mins to warm up car.
  4. fuzzy1
    10,603
  5. 48mpg
    48mpg Member
    193
    47
    florida
    I
    only drive down hill you will see a giant leap in MPG
    increase tire pressure to around 42psi
    cost as often as possible
    take heavy un needed junk out of the car
    watch the you tube videos on hypermiling
  6. Wolfy90503
    Wolfy90503 Junior Member
    56
    Torrance, CA
    I have learned not to trust the computer MPG as the actual MPG calculated at gas pumps can vary greatly...as much as 7mpg in my case. For me the fluctuations are mainly due to temperatures.
