dashboard phone mounts
Discussion in 'Prius c Accessories and Modifications' started by winnertakesteve, Dec 30, 2015.
  1. Kurt Weiske
    Kurt Weiske Active Member
    178
    131
    I have a Spigen magnetic mount that clips into the vent grill. It's unobtrusive when the phone is not there, and with the Spigen slimline case, there's an indentation inside the case for the metal panel that the magnet attracts. It stays put, doesn't wobble, and can hold the phone in portrait or landscape orientation for music or maps use.
    Bigboi likes this.
  2. Nate28
    Nate28 Junior Member
    San Diego
    +1 for proclip, used it since I got my C in 2012, love it. Super sturdy, I can slip my phone into it for instant charging, perfect placement, barely have to move my right hand off the steering wheel to use navigation/phone features. Expensive, but worth it IMO.
    Bigboi and Xterra72 like this.
  3. AliIzad
    AliIzad Member
    170
    72
    Southern California
    I have tried several different styles and Proclip is by far the best that I have used. 2.JPG 1.jpg
    Nate28 and Xterra72 like this.
  4. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    This one is pretty neat and sits in the front panel pocket secured by 3m tape. Not a perfect fit. It's meant for right side drive vehicles. Barely fits a 3in wide phone. Google: sy-a3
  5. SamanthaC0716
    SamanthaC0716 Active Member
    333
    115
    Ordered this one off of Amazon. I currently use one that is magnetic and clips to the vent, and I don't love it. Hoping this one works out.
    Scosche MAGDMB MagicMount Magnetic Dash Mount for Mobile Devices
    (I'll have it in 2 days and will update.)
    #25 SamanthaC0716, Mar 19, 2016
  6. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    Scoche's good mount, I put it to the right of the Car/Apps/Setup button. Then I put the magnetic plate inside my cellphone but it actually put a crack on the side of the cover because nothing was meant to be wedged in there. Works fine if you have a regular case though or just stick it on the back of the phone directly!
  7. SamanthaC0716
    333
    115
    Here we go. I like it much better than the vent-mounted one that I was using. It doesn't block anything that I need to see. The switch for hazards is slightly behind it when phone is up, but it's thankfully rare that I need access to that.
    iPhone ?
    #27 SamanthaC0716, Apr 11, 2016
    Bigboi likes this.
  8. Lilpig
    Lilpig Junior Member
    new york, ny
    2014 Prius Plug-in
    For over two years I've been using the Nimbus Mount and its def the best way to go.
  9. christinec7
    christinec7 New Member
    Cerritos, CA
    2015 Prius c
    I also got the Kenu Airframe+ a few months ago. It works well enough for me. It's secure in my middle vent (closer to driver side) and I haven't had it fall out unlike some magnetic ones I've tried. Good purchase
