turn off without press 'p'?
Discussion in 'Gen 3 Prius Main Forum' started by fileaudio, Mar 14, 2016.
  1. fileaudio
    fileaudio Member
    109
    58
    El paso texas
    will it hurt the car
  2. Mendel Leisk
    41,301
    I can't remember the last time I pushed Park.
    fileaudio likes this.
  3. Sillywizard
    Sillywizard Junior Member
    Sweden
    One saves three milliseconds of energy by pushing on/off directly, than "P" first, then power button...
  4. BZzap!
    BZzap! Senior Member
    1,607
    878
    I've come into a parking spot with ICE not running (no visceral awareness) and unconsciously open the door to exit with the car still in "D". Getting into the habit of using "P" before you let your foot off the brake ain't a half bad routine to practice. Then there are those of us that never, ever get distracted.
  5. yeldogt
    yeldogt Active Member
    810
    313
    NE
    I just turn the car off.
  6. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    No, I don't think it will hurt anything to just hit the power button. That's all I ever have done to either my 2004 or my 2010.
  7. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    The correct answer is "no it won't hurt the car". The Prius goes into "P" automatically when you turn it off. If it's moving slowly it's probably not a good idea, but if stopped it's fine.
    Bay Stater likes this.
  8. fileaudio
    fileaudio Member
    109
    58
    El paso texas
    ohhh im sorry i forgot the search before post... not its areplicated thread but is good to know ..... i was lokking for the tricks and hint tricks too... and there are some..... im quite happy with my prius ,,like a child on chrstmas
  9. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    For those of us who are easily distracted, why would it be easier to remember to push "P" and then push the "Power" button than to simply push the "Power" button? A one-step shut-down procedure should be easier to manage than a two-step procedure.
    fileaudio and Bay Stater like this.
  10. BZzap!
    1,607
    878
    That's a good question. Maybe they put the "P" button on the car for some obscure federal safety requirement. I know I use it because I guess I just like to push buttons.
  11. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I use the "park" button when I leave the car running with my wife in it, then I get out to do something that only takes a few minutes or less. Typically, my wife needs to remain warm or cool while she's waiting.
    Chilly36 and fileaudio like this.
  12. BZzap!
    1,607
    878
    That's a real good reason for the "P" button.
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I trained myself not to use the P and to always shut off with Power. With a silent engine, it would be very easy to walk away from the car "running" in my garage.
  14. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Me too! Found out by accident.
