prius 2010 hybrid battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mohammed khan, Mar 19, 2016.
  1. mohammed khan
    mohammed khan Junior Member
    44
    fiji islands
    i have just recently bought a used prius 2010 with about 130,000 km mileage. i wanted to know roughly after how long would i need to change the hybrid battery or how long will it last roughly. do i need to change the whole battery or the individual cells to make it new again.
    thanks
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    779
    308
    Maine
    We have over 150,000 miles.
    When we passed 100,000 miles I was anxious. I asked the service manager what he told me was that he routinely sees Prii over 200,000 and 300,000 still on their first battery.
    mohammed khan likes this.
  3. mohammed khan
    44
    fiji islands
    thanks for the reply. so when and if it comes to battery replacement is it that the whole hybrid battery needs changing or just the individual cells in it
  4. ForestBeekeeper
    779
    308
    Maine
    The whole thing gets replaced as a unit.
  5. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    WilDavis likes this.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,720
    1,761
    Bay Area
    You can replace individual cells or the whole unit if you want, but replacing the whole unit would be the easier route and cost around 2800$. If you're replacing the individual cells, you will have to find a unit that you can remove it from and replace it with your cells. It's a little time consuming but its a cheaper route.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    In my opinion it's nearly impossible to really predict when the hybrid battery may fail.
    If I was you? If vehicle performance seems "normal", I'd just to with it.
    When it fails, you'll know it.
    You could wake up tomorrow with it in trouble, or go years and many, many miles trouble free.
  8. bisco
    52,274
    just replace a cell as needed. are you capable of diy?
  9. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    OP's (Original Poster) location say he is in Fiji. Climate wise, Fiji is nothing like Maine.
    I am only aware of a few Hawaiian members who have had HV Battery failures, and it still seems to fall in line with most: 100K miles - 150K miles [160,934km - 241,401km]
    Buying new Battery/ Core Credit | PriusChat
    This person lives in Maine, where it its COLD; Maine gets SNOW, Fiji does not.
    HV Batteries seem to last longest in cold environments, and when the terrain is flat.
    Heat (ie, desert) and mountains seem to give the HV Batteries the shortest life span.
    For TROUBLE FREE operation of the vehicle, you want to replace the entire HV Battery pack with a brand new HV Battery pack.
    If you have more time than money, module replacement may be for you, but it is a temporary solution. This approach does not last because the remaining modules are still old, and you just introduced a module of unknown quality (maybe weaker or stronger, than the original modules in your pack). Yes, it is possible you may get months, a year, or even upto two years, with this repair, but it is more likely you will get months at best. And, Murphy's Law will have the repair fail at the worst possible time and location: hundreds of KM from home, during an epic typhoon.
    Ideally, OP is setting some money aside every month, to cover said repair, when the time comes. The closest Toyota dealership, to me, will sell the HV Battery for $2071 USD. But, when one amoritizes it in terms of total miles driven at the time or replacement, the cost is reasonable; the more miles, the cheaper per mile cost.
    $2071/150K miles = $.0138/mile
    $2071/155K miles = $.0133/mile
    $2071/160K miles = $.0129/mile
    For OP, I would go by years, as an indicator. As you get closer to 2020, start preparing for an HV Battery repair/replacement.
    #9 exstudent, Mar 19, 2016
    mohammed khan and fotomoto like this.
