calling rim experts
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ilovegirls, Mar 18, 2016.
  1. ilovegirls
    ilovegirls Member
    177
    San Diego
    Hello.
    I'm looking to pick up a set of rims. I don't understand offset that much and I don't want to guess. I tried to read up on offset on tire rack and other sites but it's too confusing. The rims I'm looking at are :
    17 x 7.5 offset +43
    My current tire size is 215/45/17. Will this put me flush with the fenders? I'm dropped about 1.25".
    Thanks for your help.
  2. ilovegirls
    ilovegirls Member
    177
    San Diego
    Ok.. since I'm a hands on type of person, one of my friends showed me how offset works and what the numbers mean relative to the stock offset in person. In this situation, my new rim would move approx 13mm towards the fender. This would make it a little more flush. Hope this helps someone out there.
  3. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
  4. ataylorracing
    ataylorracing ataylorracing
    171
    29
    Fishers, IN
    Using the same size tires in your tread...compared to the stock Prius 17s
    Stock rims are also 7.5 inches in width...only the 45 mm off set on your and 43 on news are different. The new rim/tire package should make everything only stick out about a tenth of an inch...no worries at all.
  5. andino
    andino Senior Member
    746
    551
    San Jose, CA
    It will be more flush than stock but not quite flush. You'll need to run an 8" width and +35 to +40 to be flush up front. Rears are flush at 9" +35
    HelloHybrid likes this.
