How does TPMS work?
Discussion in 'Gen 4 Prius Main Forum' started by pakitt, Mar 22, 2016.
  1. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    My Gen4 (arriving mid-July?) will be the first car I drive with TPMS.
    How does it work and can you set the pressure to be tracked on the tires to whatever value you wish?
    With what change of pressure does the light come on the dash?
    Does it consider pressure changes due to warm up of high temperatures of tires?
  2. Mendel Leisk
    41,402
    Assuming it's same system as third gen: you can change pressures, and then re-establish the system with that new pressure. There's a button under the dash that you push. Actually, if you google "Toyota Techinfo" and go to the "manuals" Tab, you should be able to download the Owner's Manual, see that instruction. I believe it has to fall a significant amount from the set pressure, maybe 20~25%? It doesn't care about higher pressures due to warm up, just a pressure drop.
    pakitt likes this.
  3. bisco
    51,895
    it's pretty cool, really. there's a sending unit inside the tyre, connected to the schrader valve.
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Well, "pretty cool" would be a readout of the -actual- pressure, a buzzer warning of dangerous deflation, and identification of which tyre is actually causing the warning.
    As it is it's "pretty basic".
    It just turns on a small light on the dash with a low tyre symbol in front of it when -any- tyre drops more than 20% from whatever set value you use.
    Each sensor has an internal battery, and if that dies it's "new sensor time", at ridiculous cost btw. Though they do seem to last as I haven't seen a failure yet.
    Oh, and I suspect the reason we don't see the actual pressure displayed is related to the cost AND, most importantly, the fact most people would panic if they saw how much the pressure actually varies with temperature! ;)
  5. Trollbait
    12,520
    I believe it will warn about being over inflated. It is just that the factory triggering threshold is likely way above the sidewall pressure. Remember a circulated story of someone that had the light come on, and just kept adding air, without checking the pressure, until the tires were up to 80psi or higher.
    Can the owner relearn the system after a tire rotation? The Sonic requires a special tool to do so. Since there is only a single warning a light that doesn't state which tire is low, it doesn't matter to me if the car thinks what the left front tire is really the right rear one.
  6. bwilson4web
    16,202
    MiniVCI reports these values. Perhaps someone will snoop the traffic and post XGAUGEs to report.
  7. Trollbait
    12,520
    Some do display individual readout for each tire, and I could have gotten the info off of the OnStar site while I had the trial subscription.
    The batteries should last at least 5 years, and might go to ten. The goal is to have the sensors work until it is time for a new set of tires.
  8. David Beale
    5,963
    1,989
    Edmonton Alberta
    The sensors cost more than tyres. A lot more. And you -can't- put in a new battery. It's "cast in place".
    The system doesn't care where each sensor is, in fact, they could be stacked in the garage beside the car and it would work. And does, just ask anyone who has separate wheel/tyres for winter and doesn't do the TPMS thing on the winter wheels. Of course when you drive out of the garage it looses the link to the sensors and gets upset (turns on the light, eventually).
    I have even seen some cars sense the wheels of the car next to them, though that was an early system perhaps not using serial numbers.
    "We are amused, but not greatly." ;)
  9. Mendel Leisk
    41,402
    What David said. The cost and complexity of maintaining the system, especially with aging sensors and/or extra rims (for snow tires for example) eclipses it's purpose.
  10. Trollbait
    12,520
    Shame people weren't conscientious enough to regularly check their tire pressures regularly then.
  11. pakitt
    2,173
    1,313
    Colorado
    From what it sounds the system doesn't really help those who check tire pressure regularly like me and it adds cost. My winter tires will come with sensors. This is also why I was told I'd need new ones and cannot keep the winter tires and wheels from the gen3.
    Apparently regulation says in Germany (EU?) that if a car is sold with TPMS on summer tires (and that is now compulsory) winter tires must have the system...
    I just hope I can inflate my tires a bit higher than what mandated by Toyota and not get a beep because of it...
    Trollbait likes this.
  12. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    You should be able to inflate to your desired pressure and then press the TPMS button under the dash to set the alarm point. There should be nothing that should limit it to Toyota's recommended pressure.
    pakitt likes this.
  13. Trollbait
    12,520
    Actually, I check my tire pressures more often than what the typical American does, but one tire picked up a nail, and the TPMS warned me about it before I had checked the pressures myself.
    If I didn't think having the warning light on would be an automatic fail for the annual inspection, I would skip on replacing the sensors when they finally died, but only those that check their tire pressures before each drive would see no benefit from the system.
    pakitt likes this.
  14. Tideland Prius
    16,553
    And yet a Camry can display tyre pressures on its MFD. I wonder how something like this is determined.
  15. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    My 2006 Gen2 TPMS batteries are now going bad (2 out of 4) at 9.5 years and 150000 miles. MY2006 was the first year Prius got TPMS.
    I got the Techstream miniVCI to read the pressures and minimize replacement costs. Right now I am just using it to zero out the bad tires to turn off the warning light. Apparently by law, repair shops are not allowed to disable the system, but with Techstream you can do so yourself.
    I think Techstream shows my alarm point is 26.5 psia and I could change that in Techstream but I am not aware that pushing the button resets it on a Gen2. Just rented a lowly Cruze and they had all the pressures displayed right in front of me.
