Uneven volume across sources
Discussion in 'Gen 3 Prius Audio and Electronics' started by LDB, Mar 26, 2016.
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    On AM/FM the volume has to be turned to ~40 for an acceptable volume level. On satellite for a similarly acceptable volume level the setting is 20. Forgetting to turn down from the 40 when checking local traffic or whatever and picking an XM channel results in a near ear splitting bombardment. Anyone had a similar experience? Know of a fix? Please call Toyota, 800-331-4331 if you've experienced this and report it. If enough calls go in maybe they'll figure out a fix and issue a TSB for it.
  2. qdllc
    qdllc Senior Member
    1,376
    400
    The issue is signal strength. I saw this with MP3 files ripped from my CDs.
    Ideally, all media should be recorded at the maximum output possible before you get distortion/noise. If you worked in broadcasting, it would be right up to the point where the UV meter goes into the red.
    Sadly, this is not so. Hence, different sources can vary in strength, and ultimately, your volume knob is just a setting on how much you want to amplify the output.
    For my MP3 collection, I used a software program that "normalized" the signal across all files, making them more consistent. I don't think there's such a creature for various inputs short of a volume control that lets you set by output db and self-adjusts as needed.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    This does not solve the signal strengths but each source has independent volume settings. Have you tried adjusting the individual settings?
  4. LDB
    LDB Member
    279
    71
    I'll have to look for info on that. I wasn't aware that was an option.
  5. qdllc
    qdllc Senior Member
    1,376
    400
    Ah, I see what you mean.
    I can't say for certain, but I've noticed (at times) that the volume for one source is different from another. I didn't expect that, and I can't quite confirm that it's so. It does makes sense, though, because the signal strength from AM/FM stations will be much lower than what you get from a CD or USB input. Letting you have different volume settings lets you set each where you find it works best so you don't have to keep raising and lowering volume.
  6. bisco
    51,891
    do you mean simply leaving the volume where it is when changing sources? i don't find that to work at all. what other way is there to 'adjust individual settings'?
  7. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    On my Prius Three my volume is also different, down to the same numbers approximately, like yours. I think this is a problem on all Prius Three(or prius with Display audio and Entune Nav). This is not a problem with the two(display audio) or the 4+(Premium HDD Navigation).
    Also, the volume on this unit is NOT independent, all sources use the same volume, so set it to 40 on FM and switch to SAT it will be 40.
    Unfortunately, I do not know of any solution other than to switch it to 20 before I go to the satelite.
  8. bisco
    51,891
    that's what i do too. when i remember.:cool:
  9. LDB
    LDB Member
    279
    71
    Yes, the problem is remembering every time.
  10. bisco
    51,891
    when i change from radio, which requires about 40, to usb which requires about 20, and forget?:eek: no wonder i'm going deaf.:cool:
