Back-up camera
Discussion in 'Gen 3 Prius Main Forum' started by Scott Dykema, Mar 29, 2016.
  1. Scott Dykema
    Scott Dykema New Member
    michigan
    Just purchased 2010 lll w/ Nav and back-up cam. Although the cam works fine it doesn't show a grid. I drove a 2008 w/ cam and that did show a grid. The salesman stated some camera's did show it and others don't. Anyone familiar with this inconsistency or is there an adjustment in the settings that can be accessed to create the grid?
  2. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    I also have a 2010 III with no grid.
  3. bisco
    52,390
    welcome! if you drove a 2008 prius with grid, it must have been aftermarket. prius has never had a grid, not sure about gen 4.
  4. cipsaz187
    cipsaz187 Member
    150
    42
    The Prius for the US market does not have the grid while the Prius made for EU market have the grid. Weird if you ask me. I miss the grid a lot.
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The grid is metric. You can't have it. ;)
  6. qdllc
    qdllc Senior Member
    1,377
    400
    I bought an OEM-style back up camera for the Prius Two. The grid is there, but if you don't want it, they tell you to clip one of the wires. Makes me wonder if Toyota has a reason for NOT having the grid visible on the Prius.
