Mystery Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Smardaz, Mar 30, 2016.
  1. Smardaz
    Smardaz Junior Member
    26
    Tacoma, Washington
    2024 Prius Prime
    XSE
    Hopefully I can word this so as to be understandable:
    I have a 2008 Prius, it runs as normal although for some time I have noticed the mileage is not what it used to be. A couple years ago a problem started that works like this:
    The car will run normally around town, however if I take a road trip that involves a mountain pass or extended incline the power on the hybrid battery will completely drain, the car will slow down and I will lose the ability to gain any more speed and the engine races if I try to accelerate. I then need to pull over and turn the car off and on and let it charge to continue.
    The dealership has looked at it several times and continues to tell me there is no problem, and nor is there any record of anyone else having this problem.
    To their credit, when you go into the hidden maintenance mode, there is no battery error message, the battery shows normal voltage with and without loads on the system. However if you go into the maint. mode that is supposed to keep the engine idling, it will not idle and shows a car with an exclamation mark and a red "warning".
    Any thoughts?
  2. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yes, there have been quite a few reports of this behavior with Gen2's as they age. Basically it's the HV battery losing capacity as it ages. They all do it, some more than others. Also some people will simply notice it more than others due to the terrain and conditions in which they drive.
    My HV battery was estimated at about 50% capacity after 160k miles and 10 years, and to be honest I don't think there is anything unusual in that. Fortunately with the terrain that I travel it's not a huge problem, but I can definitely see that it would be for some.
    The dealership won't do anything (and it wont qualify for warranty replacement) unless it throws a code. The bottom line is that you can lose A LOT of capacity on the HV battery without it throwing a code, provided that the cell balance and internal resistance remains reasonably ok.
    BTW. I cant find the post right now, but from memory only one guy here has ever reported getting a warranty replacement over this issue. Essentially he kept taking it back to the dealers and bugging them with it. They even got specialist Toyota techs in and test drove it extensively, but they gave it the "all clear". Still he kept at them and eventually they caved in and gave him a new HV battery, which fixed his "hill" problems straight away. Anyway, I think it would take very good luck (or a lot of persistence) to get similar treatment to this "one off" case.
  3. Smardaz
    26
    Tacoma, Washington
    2024 Prius Prime
    XSE
    Thanks, I prob should have mentioned that since buying it new in 2008, I have put 220,000 miles on it....I've not been gentle.
    Is there any merit into replacing the battery myself? Is it feasible and/or cost effective?
  4. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yeah the hills and mountains can push the batteries pretty hard. At 220k miles this would definitely just be normal "wear and tear". The Gen2 really does rely a lot on the battery to "cover" for the lack engine power (in relation to the car's weight) when hill driving. The problem is that the battery can only cover this for a short time, and if you continue up a very long hill at high speed (with the battery having to supplement the engine) then state of charge will fall until the point where it will no longer supply power, and has to try to recharge itself by draining engine power.
    At that point you basically get a "double whammy". The battery stops assisting, but it also starts draining some engine power as it desperately tries to recharge. At this point the Prius is most definitely sluggish.
    It could be if the rest of the car is ok. I think some dealers have been selling new Batteries for as little as about $2k. There's a thread about the best place to buy a replacement battery somewhere here.
  5. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    Hi :)
    My battery depletes (1-2 purple bars) after about two miles of aggressive hill climbing particularly at highway speed then the engine works hard to compensate, I know my battery has excellent capacity, have never compared it with a brand new car but would expect any hybrid to act similar.
    When battery fails totally charge will very rapidly swing between full 8 green bars of power down to 1 or 2 bars even in normal city driving conditions.
  6. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yeah, there's no reason why it couldn't happen even with a totally new battery. It all comes down to driving with a power demand that exceeds what the engine can output. The Prius HV battery can cover for this extra power for a minute or two, but when it's gone it's gone, and then you've got to live with the reduced output or give it a chance to recharge.
    One other thing to consider before looking into a new battery is that a decline in engine power can cause the same situation. So at 220k miles it could well be a combination of both reduced battery capacity and reduced engine output.
    rifis likes this.
  7. Taimur
    Taimur New Member
    Pakistan
    Hello everyone I am new.... Don't know much to use this site...... I drive prius 2011 3rd Gen. Yesterday while driving I heard a bang sound and after that car was filled with smoke arising from battery pack.... I de-assembled the battery pack, cell number 20 got exploded, damaging 19 and 21. Cooling fan is working perfectly fine, All battery cells are showing 7.8 or 7.7.... The one got exploded is now at 6.4....i changed three cells now it's working fine but I am worried why it exploded at first instance.
