Going from Prius Four, not IV because it isn't a 2010 15" wheels to 17" please help
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PriusCatMouse, Apr 6, 2016.
  1. PriusCatMouse
    PriusCatMouse Junior Member
    31
    Your Prius looks great! I get my 17s tomorrow and maybe the LRRs will offset the MPG I'll lose with the larger wheel :D
    And thank you I really like my Prius and I'll keep it until I get my Tesla 3 in a few years (unless the lack of a true hatch back bugs me too much lol)
    dorunron likes this.
  2. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    My understanding is the 17" wheels were not put on the same cars as the solar roof to keep the weight below a certain value, to allow the best fuel economy rating. Maybe the rating system is different in Australia. Or maybe they don't care. They just want to sell -fully- equipped cars. ;)
  3. PriusCatMouse
    31
    Hi all got the stock 17s today with the Ectopia EP22 getting installed right now.
    What tire pressure do I have them put them at?
    Front 42 rear 40 or front 40 and rear 38? Or just max 44 on both front and rear?
    Thank you
    Bay Stater likes this.
  4. JC91006
    JC91006 Senior Member
    16,936
    8,647
    hope you got your original TPMS sensors back
    I do about 40 lbs on mine and it's pretty good.
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Pump em up to what you are comfortable with ride wise. Keep at least one to two pounds more in the front one's than the rear. Observe the maximum inflation pressure stamped on the side of the new tires. The Michelins on our Prius have a max of 51. At 51 F 50R the ride gets pretty rigid. If I drop it back a little bit, the ride gets smoother. Make it where you are comfortable, but put as much air as you can in them. More air lower the resistance to roll, whereas less air makes the tire have a higher rolling resistance...
    EDIT: Don't forget to set your tire pressure's when the tires are COLD. ;)
    #25 dorunron, Apr 7, 2016
  6. PriusCatMouse
    31
    The max is 51. Right now I have them at 42/40 it rides very nice. I will have to increase them to 46/44 and see how it rides. If it gets too rough I can always back off a bit to adjust.
  7. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Is there a reason to lower the back ones by 2 psi than the fronts? Thanks.
  8. 348
    348 Junior Member
    71
    36
    Central Oregon
    image.jpeg 17"s are sexy and Enzo handles quite well
    I get 46-48 mpg having fun behind the wheel.
    #28 348, Apr 7, 2016
  9. frodoz737
    frodoz737 Top Wrench
    4,808
    2,562
    33
    Weight distribution. Front is heavier. My experience with the Gen III Prius is 42/40 psi is a good balance for ride and even wear. Much more and center tread wear increases.
