Engine oil cooler?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Morgan F, Apr 9, 2016.
Tags:
  1. Morgan F
    Morgan F New Member
    Appomattox, VA
    New to forums here, be kind!
    I drive a LOT. I mean, a whole lot. 5 days a week, 400 miles a day (200 mile commute). *edited* For nearly all of that drive, I'm doing 70-80mph (with...uh...sprints higher to shed the frickin limpet mines that have no idea what speed they want to do till they're passed by a Prius @*&$&@(*@...ahem, back to our normally scheduled programming)
    I'm considering an oil cooler and was wondering if anyone bouncing around here has had any experience with them on a Prius?
    douglasjre likes this.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    since the ICE doesn't run all the time, and a lot of folks are blocking the radiator with no ill effects, I don't think an oil cooler is necessary. I would suggest using the best oil and filters you can get your hands on. I think amsoil claims their oil is good for like 15K. and someone here has found a larger filter that fits; that might be a good idea too.
    Morgan F likes this.
  3. Morgan F
    Morgan F New Member
    Appomattox, VA
    Thanks for the quick reply! A larger filter sounds like a good idea. However, my ICE is running, and running fairly hard for 97%+ of my drive, so out of 400 miles, there's only about 10 miles the ICE gets a chance to shut down (stop go traffic+speed limits around 35/under) Under these conditions would a cooler help or am I accessorizing for nothing?
    I use Mobil 1 and Mobil 1 filters currently.
  4. Kenny94945
    Kenny94945 Active Member
    856
    433
    Sausalito
    2016 Prius v wagon
    You may be accessorizing for nothing.
    The question is what is the engine temperature and what is the engine oil temperature?
    What symptoms make you think you need more engine cooling?
    Maybe some no cost accessorizing would be to remove the grille/ anything blocking air intake to the radiator.
    Keeping the radiator/ ac condenser area free of leaves and debris.
    Perhaps placing some NACA ducting in the undercarriage fairings/ plastic shield panels to gather air from under the car and move it to the engine compartment.
    Quality synthetic oil, extra large oil filter are good ideas.
    Oil cooler, many options, cost...$400?
    Good luck in your decision.
  5. bisco
    52,292
    welcome! you might want to invest in a scan gauge to watch rpm's and temps. how many miles on your car?
  6. Morgan F
    Morgan F New Member
    Appomattox, VA
    Thankyou!
    Answer to your main question is I don't have any specific faults (unsure how to get engine/oil temps...sure I can find it here in the forums.)
    My goal, however is to keep something from developing, and it seems keeping oil cool will assist in it's longevity. I have a bit under two years with this commute.
    Costs seem to run ~$150 ($135 for cooler, and added for associated small parts)
  7. Morgan F
    Morgan F New Member
    Appomattox, VA
    183,00 now, I bought it at 97,000 about two years ago (I do a lot of travel out of local area, so don't drive the vehicle periodically).
  8. bisco
    52,292
    wow! all the best!(y)
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Derale Stacked-Plate Engine Oil Cooler Kit w/ Sandwich Adapter (Multiple Threads) - Class III Derale Engine Oil Coolers D15605 has thermostat so it does not 'cool' cold oil (180 F)
    Derale Stacked-Plate Engine Oil Cooler Kit w/ Spin-On Adapter (3/4-16 Threads) - Class III Derale Engine Oil Coolers D15651 if you want to relocate oil filter
    While I question the need for an oil cooler, these will not cool when unneeded so should not harm anything.
    They sell cheaper kits with no thermostat, but I worry they would hurt efficiency. Derale Tube-Fin Engine Oil Cooler Kit w/ Sandwich Adapter (13/16-16 Threads) - Class III Derale Engine Oil Coolers D15503
    #9 JimboPalmer, Apr 9, 2016
  10. Mendel Leisk
    41,828
    Yeah wait a sec, there's already a REALLY serious cooling system in the engine: glycol coolant, big radiator in front, maybe sleep on it?
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It is his money to spend, I am just trying to make sure that he does no harm. Everyone has different needs to spend money, at least he is not asking how to make his car louder. He just wants to be cool. Now cooling the transaxle, that would be hard.
  12. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    From my experience with past cars cooling the transaxle makes more sense than cooling the engine. I had a Volvo s80 which would have its transmission fail due to overheating. The fix was a external cooling method.
    That may help the prius, but I somehow doubt it
  13. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    With a VERY small oil pump and no filter, it would be hard to tap into the transaxle to get ATF under pressure. I think you would need an external electric oil pump.
    http://www.summitracing.com/parts/til-40-524/overview/ That is way more than the entire kit for the engine. The Prius transmission may make far less heat than one with a torque converter. (One reviewer claims this pump is louder than his race engine. "In a gutted race car with just a pair of Flowmasters (no tips or tail pipes yet), you can EASILY hear this pump over the running V8 and exhaust noise")
    The existing oil pump in the transaxle is briefly mentioned here at 7:35 to 7:55.
    And can be seen here from 5:05 to 7:10
    #13 JimboPalmer, Apr 9, 2016
  14. 69shovlhed
    2,170
    752
    Delaware
    wrong, the fix was to send that POS Volvo to the scrap yard. a Volvo is a urinal with wheels.
  15. Mendel Leisk
    41,828
    All I've ever heard with engines is get them UP to optimum temperature, as efficiently as possible, and then the engine coolant, rad and fans deal with any overshoot. An engine oil cooler seems a fool's mission.
  16. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  17. Morgan F
    Morgan F New Member
    Appomattox, VA
    Well, wasn't planning on sprinting to the warehouse in wherever-it-is just this evening. I may wait till early morning. Maybe.
    Seriously, I appreciate all the feedback!
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Because it is not a highly stressed engine typically, there is no oil temperature sending unit or even an oil pressure unit except a digital 'good enough' and 'boy you are in trouble' switch. adding a oil temperature gauge to find out if you have any worries may be cheaper than starting with the idea that you need a cooler.
    This non thermostatic sandwich adapter is drilled for an oil gauge sender and if you need to add an oil cooler later, it is drilled for that. http://www.andysautosport.com/products/spyder_auto__ACC-032-SL.html
    Here is a Gauge in Fahrenheit with a sender, all you need if you know a place to insert the sender in the Toyota engine block. Amazon.com: Dewhel Oil temp temperature Gauge Universal Meter 7-Colors LED Smoke 52mm 12V 120-300 °F W/ Sensor: Automotive
  19. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Hahaha. We used to be a Volvo family. After ford bought it it became utter crap. Basically the s80 fell apart one piece at a time. Never again.
  20. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    You may want to consider an oil cooler once you determine that the temps are consistently staying above the norm. The manual say's 87C is the opening temp of the thermostat and that is about 185F give or take a few.. I couldn't find anything about the oil temp tho.
    With the ELM327 and Torque app you can probably monitor those temp while staying in a low budget range before buying any additional cooling system.
    I actually don't know if you can control the fan speeds with the torque app in the genII but with Scangauge I believe you can manually control it to help with the battery temps. Others have added inverter coolers when noticing high invertor coolant temps..
    #20 Justdidit, Apr 11, 2016
