Prius 4 2016 Liftback
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by FrankKK, Apr 9, 2016.
  1. FrankKK
    FrankKK New Member
    Chicago
    I just took delivery of a 2016 Prius Four Liftback It doesn't have a spare. Toyota supplies some kind of chemical and an air pump to stop the leak and add air. Does anyone have any experience with this system. How easy was it to use? How far can you travel?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I find the 'goop' useless in most situations, that's why I personally won't buy another car without a spare (I owned a Volt with no spare and went through hell one morning due to a pothole hit). Anyways, avoid using the goop IMO.
    Basically, the 'goop' is made to seal a small hole caused by a nail, screw etc. Well, generally when you get a nail, screw etc you can leave it in and the tire holds enough air to continue driving, occasionally adding air as needed until you get it patched/plugged. So, unless you remove the object, you don't need the 'goop'.
    Now, if you have a severe enough strike that causes a blowout, the goop is useless and you would need a spare tire to get going. Instead of putting on a spare and getting on with life, you have to press the button in the vehicle that has a tow truck come and takes you to a place for tire repair/replacement.
    So, the 'goop' is basically useful if you run over something that puts a small hole in your tire but doesn't stay in the hole in the tire, which often IS NOT the case.
    That's my take on the stuff, but after many threads here on this and missing spare tires, you'll get many varying opinions on the subject. Some say add a spare of your own, but I personally will not strap a spare down in my cargo area or put it behind on of the rear seats taking up space I need because they couldn't design the car with on it is already.
    pjm877 and Coast Cruiser like this.
  3. Steve_M
    Steve_M Junior Member
    Maryland
    Why wouldn't a 2016 Prius Four have a spare tire? I thought that, for the 2016 models, only the Prius Two Eco came without a spare. Or were you referring to "Fourth Generation" (rather than "trim level Four?") when you said Four?
  4. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    The four and four touring also don't have spares, presumably to offset the weight addition from the things like the power seat so they don't have to state a lower MPG
    Coast Cruiser and Steve_M like this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    The instructions in the manual say to leave the screw or nail in the tyre and apply the goop as the goop might not seal the tyre if you take out the screw/nail. It then goes on to say, inflate the tyre, run for 20 minutes and re-inflate. What a fuss, the instruction proves that the goop does nothing, when you find a nail in the tyre, pump it up and find it holds pressure, then you don't need the goop, so why even bother ?
    The only useful thing in the kit is the electric pump and you can probably buy one of those for $10. The other thing is, the goop in the kit has a 5 year shelf life and costs three quarters of the price a new tyre to replace.
    My UK Gen 4 Excel with 17" wheels came with the goop kit but, as part of the deal, my dealer ordered me the temporary spare kit as a replacement, it should be here next week.
    Coast Cruiser likes this.
  6. bisco
    52,390
    welcome! the goop is only good for some punctures, and some people have added a plug repair kit. you can also add a spare under the deck if you choose, there is at least one thread in the gen 4 forums covering all this. congrats on your new wheels, all the best!(y)
  7. Mendel Leisk
    41,901
    I'd go for the aforementioned plug repair kit, and try to avoid using the goop kit at all costs. Chances are if it's not pluggable the goop won't work either. You'll also need some alternate source of air, the supplied compressor won't operate without using the goop. Even a decent, full size bicycle pump will work. I've plugged repaired a tire (after installing the spare, makes it a lot easier) and then brought the pressure right back up with just a bicycle pump. It's not that hard.
    Depending on your situation, it might be worth your while to pick up a temp spare, or even an extra full-size tire, mounted on a Corolla rim. If you do nothing but local travel, just having one on hand might work for you: even leaving it home, if you get a flat, taxi home and back to get the spare, if you don't want it rattling around in the trunk all the time.
    Temp spare is ideal, but hard to find and pricey. Full size can actually be cheaper. If you're interested in the latter I can post the part number, there is a compatible Corolla rim.
    Also, a St. Christopher medal dangled from the rear view? :)
    Coast Cruiser, glennonrp and bisco like this.
  8. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    In about 40 years driving, I would guess I have had about 6 flat tires. I say guess, because none was traumatic enough to be burned deeply into my memory.
    My experience is probably unique, but I can say with 100% certainty none was a blow out. Each was discovered either in my driveway, or at work.
    In several cases I used a can of Fix-a-Flat and it worked great. I became such a fan that I have a can in my desk drawer at work (they say not to freeze it). I have helped 2 strangers with flats -- giving the full disclaimer regarding goop (I didn't have pressure sensors when I used it).
    The last time I found a flat was last year after letting my car sit for a week. For that I got a cheap compressor and filled the tire without goop. Held the air enough from the time I filled it on Saturday until I got to the tire store on Sunday.
    The thing I don't like about the compressor solution for the Prius is that you must use the goop-- no choice.
    Since I have fantasies of saving the day by doing a virtually permanent tire plug on a tire (or two!) on a Maine loging road, I am keeping my compressor in a gym bag in the hatch -- right next to my Glock trenching tool, bolt cutters and some tools that I am not really qualified to use to thier full advantage.
    My fall back plan is walking.
    KrPtNk likes this.
  9. Mendel Leisk
    41,901
    I've got two plug repaired tires right now: one of the OEM and one snow tire. Both have at least a couple of years post repair, no problems.
  10. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The air pump that came with my Prius only works with the gunk container screwed in. So I assembled the kit below, using parts available at any auto parts store:
  11. FrankKK
    FrankKK New Member
    Chicago
    I am interested in a temp spare. Will a Corolla rim fit my 2016 Prius 4? What year Corolla?
  12. Mendel Leisk
    41,901
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    AFAIK, 3rd gen and 4th gen rims are interchangeable. I got the above with snow tires, at the dealership, and they said even they were not sure, I was the first they tried it on. It was fine though.
  13. Frederickdawg
    Frederickdawg Active Member
    596
    336
    Florida Unfortunately
    Question, isn't not possible to get the Prius eco trunk trim parts and add a space saver in a trim level 4 car?
    LG-H901 ?
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    My dealer got me a space saver to replace the goo kit, but forgot to get the polystyrene trim bits, he has ordered them for me, so they can be obtained. It looks like it will raise the trunk floor by about 3" with the wheel in.
    update, the trunk trim pieces are on back-order from Japan, expected sometime in June. I expect there's a lot of people wanting the wheel kit, as it's a no cost option here in the UK.
    Frederickdawg likes this.
  15. Frederickdawg
    596
    336
    Any possibility of perhaps compiling a parts list needed for retrofit?
    LG-H901 ?
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Will do when I get the bits.
    Update, the dealer only ordered the central foam that covers the wheel (£200 GBP), that means there's nowhere to put the jack, so I've reverted back to leaving the temporary spare on top of the deck in the boot. The whole caboodle is the wheel and hold down bolt, 3 pieces of foam and a different top deck cover, ends up costing around £500-600 GBP plus the wheel.
