Radio at full volume at startup
Discussion in 'Gen 2 Prius Audio and Electronics' started by astrorat, Nov 26, 2015.
  1. astrorat
    astrorat Junior Member
    Tyler, TX
    Hello,
    I am an occasional lurker who appreciates the great information on PriusChat. An intermittent problem has showed up over the last few weeks that is quite distressing when it occurs.
    When starting the car, the radio comes on a full volume. Turning volume control knob does not help, but only turning off the radio or turning off the car. [This only occurs if the radio was left on when the car was shut off previously.]
    Also, the problem is noticeable if the radio is off and the buttons on the navigation system are pushed resulting in a high-pitched "beep." Then I turn the car off, then on again, and everything is back to normal.
    This happens about once or twice every couple of weeks.
    Any thoughts on what I need to repair or replace?
    120,000 miles
    Navigation system
    Thanks in advance.
    RGBrun likes this.
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,068
    548
    Tucson, AZ
    2021 Prius
    I'll take a guess and suggest you check out the condition of the 12V battery. All sorts of strange electrical things begin to happen when that battery is on its last legs. Being a 2008 though, the battery has probably already been replaced at least once. Give it a check. It doesn't sound like a loose plug or damaged wiring sort of thing. I don't think I ever left the radio in my 2008 on when turning off the car. It should just come back on at the volume level it was turned off at, I would think.
    kenoarto and Lucifer like this.
  3. fuzzy1
    10,603
    That symptom would be a new one, but for more detail, OP should check here:
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    kenoarto likes this.
  4. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    I agree with the 12v unless there's possibly a disgruntled significant other or a mischievous teen with access to the vehicle;)
    A weak 12v manifests itself in unusual activity, I had the radio out of control myself, mine was after a dealer visit, 12v was good but they ran it down, prii are digital devices after all.
  5. fuzzy1
    10,603
    Or a hard-of-hearing dad.
    The same one who kept shutting off the car with the windshield wipers up, so they would freeze overnight in an up position and try to break themselves when I started the car in the morning to go to school. I would always make sure the wipers were parked and off before shutting the car down, so the next day I could warm the car and get some engine heat on the defroster before trying to scrape the windshield and run the wipers. But dad was untrainable.
  6. astrorat
    Tyler, TX
    Thanks, everyone.
    When the radio comes on at full volume, it's independent of the volume when the car was shut off. The weird thing is that the volume knob won't turn down the volume.
    It sounds like a great thing to check is the 12V battery. It's still the original battery so it may be on its last legs.
    Thanks for the link to do on on-board check of the battery. Now I just need to figure out where the MDF button is!
  7. astrorat
    Tyler, TX
    I figured it out, finally. It looks as if my 12V battery is starting to fail (9.8 V under no engine load). I ordered a new Optima battery and will install when it arrives.
    The difficulty I was having was in "turning the lights on" three times, I was turning the headlights on rather than just the parking lights. So I was going "two clicks" rather than just "one click" which was not engaging the diagnostic screen.
    #7 astrorat, Nov 28, 2015
  8. RGBrun
    RGBrun Junior Member
    Atlanta
    Did this fix your radio problem? I am having the exact same problem in my 2008 prius. Every now and then, when I turn the car on, the radio blasts out my ear drums. The volume is very loud and whatever music is playing sounds very distorted. Turning the volume knob has no effect on the volume of the car. The only fix I have found is turning the car off, waiting a while and then turning the car back on. If I turn the car off and do not wait long enough before turning the car back on, the problem still persists.
    I tried the above proposed solution of checking the 12v battery, however all my voltages were within the normal ranges specified in the post. So, unless there are further tests that can be done on the 12v battery, it would appear that is not the problem.
    Not sure if this is relevant to the radio problem, but I have noticed a drop off in MPG (40's --> 35). Additionally, I have been having issues with the keyless entry not working immediately when I put my hand on the door handle sensor. Furthermore, sometimes when I go to lock the car using the door handle button, the car thinks they key is still in the cabin of the car.
    For the radio, I was trying to decide if I needed to replace the stereo head unit or perhaps the amplifier. But if I can get other suggestions that won't cost on the order of 100's of dollars, I would be ecstatic.
    JBL Speakers, w/o Navigation
    100k mileage
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    you might need to load test the battery to be sure its good. lately I have seen several batteries (not prii) that would act like they were good-- the headlights were very bright and all the accessories worked fine until you tried to start the car. as soon as the starter was engaged the batteries would internally short and lose all power. let go of the key and the lights would come back on bright. since the prius doesn't have a strarter, a bad cell might cause different problems than a normal car.
  10. astrorat
    Tyler, TX
    I thought I had the problem fixed by changing the battery, but the problem did not go away. I finally made the time to find a used JBL amplifier from a 2008 Prius on eBay and replaced the original amplifier (cost was $38 and took about 45 minutes to replace). I hope this will fix the problem. So far ... so good.
    RGBrun likes this.
  11. astrorat
    Tyler, TX
    It's been a little over a month without the radio problem. It looks like it was the amplifier was the culprit. Woo hoo!
    RGBrun, bisco and Mendel Leisk like this.
  12. bisco
    52,395
    congrats! thanks for the update.(y)
  13. Mendel Leisk
    41,912
    We had a home mini stereo system that had a similar problem. As long as you used a remote to adjust volume it was fine, but do any adjustment with the set front knob, volume would start running up and up. Finally recycled it recently, wasn't seeing any use anyway.
  14. RGBrun
    Atlanta
    I ended up having the local Toyota service center look at the issue when I was getting an oil change. I don't particularly have much confidence in their diagnosis, it kinda sounded like they didn't know so they just came up with something - however, I have not had problems with the radio since. They told me that I had the "ASL" button on (which stands for Auto Sound Leveling") and since turning it off, i haven't had a reoccurrence of the problem. I suppose I could see that if the code logic was poorly written and there was a bad microphone, then the ASL could potentially tell the audio speakers to turn up the volume an insane amount - but i don't see where the audio distortion would come from or why the volume knob would no longer work.
