2016 Prius Owners Manual
Discussion in 'Gen 4 Prius Main Forum' started by PRPrius, Dec 12, 2015.
  1. bisco
    51,829
    did i say fly?:eek: i meant tie!:p
  2. OWG
    OWG Junior Member
    86
    Barrie, Canada
    I think every car I have owned has had a low washer warning. This is one of the things that bugs me the most on the Prius. Clearly the designers aren't living in a snowy region with lots of road salt. I can't stand finding out I am low when I am out, in the middle of a commute.
    retired4999 likes this.
  3. bisco
    51,829
    me either. it's forced me to check mine regularly. pita.
  4. ETP
    2,802
    1,170
    Auburdale FL
    Checking with my dealer. All may not have it. News at 1000.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It doesn't have a wheel well as such, just a slight (about 2") depression in the boot floor, in the shape of a tyre, with a threaded mount in the centre for the wheel holder. It seems, the polystyrene foam fits around the wheel and fills the boot floor, raising it by a few inches over the height of the floor with the goop kit. Mine's got the goop at the moment, I'll confirm this if/when I get the spare tyre kit next week. I hope there are some storage areas in the foam, as it seems a lot of wasted space if not.
    merged
    Not on the UK models :(
    #45 kithmo, Apr 10, 2016
  6. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    Could it be possible that this feature is turned off when you get the car, and only availble to those with a super secret decoder ring?
    Meaning a Carista module.
    Jim in NC likes this.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    According to the EU manual the feature is off by default (maybe because we don't have the moonroof option here) but customisable by the dealer.
  8. ATHiker
    644
    560
    Massachusetts
    Four Touring
    The feature was turned off on my car too, but I activated it with the Carista Modual and App.
    Not sure when I will ever use it, since it only opens the Windows, but does not close them. Perhaps on a hot day as I walk to my car in a big parking lot?
  9. Jim in NC
    Jim in NC Active Member
    217
    266
    28
    Myrtle Beach, SC
    ATHiker, it is!
    I have one of the cheaper models (Eco 2) and I just got a Carista this week and changed that setting. It does roll down all windows when you press and hold the UNLOCK button on the remote. There is no remote rollup though.
    #49 Jim in NC, Apr 10, 2016
  10. Tideland Prius
    16,544
    Keep us updated. @Jim in NC says his Two Eco has it.
    It's off by default. You have to get the dealer to turn it on.
    Same here. It's off by default too. You have to read the manual and actually catch it to realise it's a customisable feature. This is why I copied the manual here to that people will see it.
  11. ETP
    2,802
    1,170
    Auburdale FL
    So the dealer said they would have to hook it up to Easy Street in the shop to do it. Problem is I bought the car 7 hours away and wonder if a local dealer may charge to do it? may just wait until the next trip. Word out on the street is that it lowers all the windows.
  12. Tideland Prius
    16,544
    The "key-in-door" allows remote up and down (although at that point, you could just press or lift up all 4 window buttons on the driver's door since all windows are Auto Up/Down). The remote fob allows auto-down (probably more useful).
    People are purchasing Carista on Amazon and using that to change the settings themselves.
  13. ETP
    2,802
    1,170
    Auburdale FL
    Anything else you need to buy to go with it?
    Thanks,
  14. krmcg
    2,592
    2,392
    Whittier, CA
    In order to make and save changes you also need the carista app ($19.95)
    ETP likes this.
