No cabin heat unless "HI"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bwilson4web, Apr 11, 2016.
  1. bwilson4web
    16,352
    A coolish morning, the sun warmed cabin felt nice when I got in. But soon down the road, the chill started to come in. No problem, turn on the heater fan and it was already set to 74, a toasty place to be . . . nothing but cool air. I increased the temperature setting . . . nothing but cool air. Eventually I set it on "HI" and warmth returned. But soon as I lowered the temperature, it soon cooled off.
    Current hypothesis:
    1. Make sure radiator coolant level in overflow tank and radiator is OK.
    2. MiniVCI check for any codes or problems.
    3. Check 12V battery (still original but marginal batteries can cause all sorts of 'funnies')
    4. Check cabin heater coolant circuit for blown fuse
    Any other thoughts or suggestions?
  2. qdllc
    qdllc Senior Member
    1,377
    400
    Thermal sensor telling the A/C the cabin temp is faulty?
  3. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    Cabin air filter?
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Is the fan operation normal in AC and non AC modes? It's common for resistors in the blower motor control to fail, commonly causing loss of certain speeds while leaving other speeds unaffected.
  5. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    Thermostat?
  6. bwilson4web
    16,352
    Fan is OK. Will check filter but that does not explain symptom.
  7. bisco
    52,351
    air in the system?
  8. bwilson4web
    16,352
    That is the coolant level issue. I got home about 4 hours ago so it should be cool enough but it is drizzling outside.
    The radar shows about 4-6 more hours so I'll go out later. I'm home, warm and dry . . . keep it that way.
  9. bisco
    52,351
    bourbon and water.
    Rebound likes this.
  10. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    That's more plausible than most of other guesses so far. A related possibility is an open circuit in wiring to that sensor.
