NGK spark plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ImranAs'hab, Mar 23, 2016.
  1. ImranAs'hab
    ImranAs'hab Junior Member
    JORDAN
    Dear all
    i have a 3 Gen Prius with 90000Mils on it.. i am thinking of changing the sparks.
    i found on the NGK site to use ILKAR7B11 for my 2ZR-FXE engine..
    any ideas on to go for Denso SC20HR11 or the above NGK.. i personally like NGK..
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    In 30,000 miles when you need plugs, I think they will be just fine.
    ImranAs'hab likes this.
  3. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Service interval in Europe is at 90,000 km, I rejected a change that soon, but will probably do it at 120,000 km.
    There are also Denso Iridium TT (IXEH22TT) comapred to OEM SC20HR11, they have 0.4 mm diameter center electrode vs. 0.7 mm. Any idea if this is any better. OEM-s at the dealers are a little more more expensive, but not that much that I would go for alternative unless there are other benefits.
    NGK Iridum IX have 0.6 mm diameter center electrode.
    Any thoughts on best option?
  4. ImranAs'hab
    JORDAN
    Thanks Dear..
  5. ImranAs'hab
    JORDAN
    Just one question....
    How did you know my car is European.. ;)
  6. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    oem denso are cheaper on ebay 8 each
  7. Rebound
    Rebound Senior Member
    3,994
    2,642
    Portland, OR
    But how do you know that merchant is selling genuine merchandise? These plugs really do use iridium to gain their long, 120,000 mile life.
  8. tankyuong
    1,555
    661
    Central MO
    100% rating and oem packaging
  9. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    at 120,000 miles, how impossible will these plugs be to get out?
  10. Mendel Leisk
    40,967
    NGK and Denso are very close, either would be fine. On our previous Civic Hybrid there were 2 spark plugs per cylinder, and Honda installed one of each (one Denso, one NGK), on each cylinder. I guess they had an obligation with each company?
    Do watch @NutzAboutBolts 's video: 90% of the job is getting TO the plugs, a lot of disassembly is required. I'd recommend a very thin application of molybdenum anti-seize compound on the new plugs, and torque to 13 lb/ft. You will need a 9/16" spark plug socket and at least a 6" extension.
    toyolover, Rebound and mgb4tim like this.
  11. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I've just had some spark plugs that were difficult to loosen... once I got to them. But, have never waited 120,000 miles with an aluminum head.
  12. Former Member 68813
    3,524
    983
    US
    i'm a big fan of denso TT plugs (the most advanced plugs available), but it's my understanding none are available for prius. are you sure about it?
    anti-sieze is fine, but one has to decrease the nominal torque or the plug will be over-torqued by about 20%.
  13. Mendel Leisk
    40,967
    @friendly_jacek Yeah 13lb/ft is reduced a bit. The spec in the second pdf I attached above says 15, presumably for dry threads.
    I'd say apply a light coat of anti-seize, then clean it off the best you can with a rag, count on there being a slight residue in the threads.
    That's what I did anyway, just an inspect and reinstall.
    Former Member 68813 likes this.
  14. Rebound
    3,994
    2,642
    Portland, OR
    The Toyota spark plug inspection procedure Mendel posted includes this note:
    "If the (spark plug) electrode has traces of oil on it, clean with gasoline before using a spark plug cleaner."
    What kind of "inspection" is that? "We pulled your spark plugs, they were covered with oil, we put them back..."
    If your plugs are contaminated with oil, you need to fix whatever caused that.
    But the valve cover gasket job doesn't look too bad. I had to do one on my BMW 328, and the entire cover was plastic, and easily damaged.
    #14 Rebound, Apr 13, 2016
  15. Mendel Leisk
    40,967
    That I had to post TWO PDFs is testimony to how messed up the repair manual is. Common sense would dictate to include the spark plug torque value WITH the inspection, but nope: it's halfway across the galaxy, lumped in with valve cover removal.
    As far as inspection, I wouldn't use any sort of abrasion on the plugs, just solvent and some sort of soft brush, say an old toothbrush. Also, the plugs come pre-gapped; I would check gap but wouldn't attempt to adjust.
    #15 Mendel Leisk, Apr 13, 2016
  16. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Changed mine at 145XXX miles and all came out normal. Replaced with original Denso Iridium, the only difference in the ones I took out with 145XXX miles and the new plugs was the color, no sign at all of tip erosion on the old plugs. If I'd checked the old plugs before ordering the new, I would still be using the original.
  17. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I'm not going through the deconstruction to open it up and not replace them...LOL
  18. Mendel Leisk
    40,967
    I've taken ours out twice now without replacing, but then: I need therapy, lol.
  19. Rebound
    3,994
    2,642
    Portland, OR
    This is odd. Isn't the US spark plug change interval 120,000 miles? That would be about 190k or 200k kilometers. Am I mistaken?
  20. Mendel Leisk
    40,967
    Canadian 2014 schedule says 192,000 kms or 144 months (12 years).
    toyolover likes this.
