Water in Fuel
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by benighted, May 17, 2006.
  1. benighted
    benighted New Member
    530
    Westport, WA
    Just an observation... If you borrow a can of gas, make sure it is the right one before dumping it in your car or it may end up costing quite a bit.
    Has anyone else ever made this mistake, or am I the only one dumb enough to admit to it?
  2. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    I'll admit it.
    I've never done that :p
  3. MarkR
    MarkR New Member
    <div class='quotetop'>QUOTE(Maytrix @ May 17 2006, 12:18 AM) [snapback]256682[/snapback]</div>
    Worst still, I filled up my diesel ute with Premium ULP :huh:
    I swore at it, thrashed it and finnaly told the dealer (it was only 4 weeks old) that it was a load of turd!
    They towed it 100km and then phoned me with the problem :eek:
    I could only cringe!
    Mark
  4. richard schumacher
    7,664
    1,045
    United States
    Do the nozzles have different diameters Down Under?
    You're not the only one (but I'm glad I never did that).
    Did you pick up a water can by mistake? Or did some doofus put water into the gasoline can (in which case you should whup them upside the head)?
  5. benighted
    530
    Westport, WA
    It was in a gasoline can. It was sitting outside so I think rain got in.
  6. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    so how did this turn out, benighted?
    DH has spent quite a few of his days tearing apart fuel systems because of non-fuel stuff making it into the gas tank. i always know it the second he walks in the door at night...
    my point is you're not alone.
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(benighted @ May 16 2006, 09:28 PM) [snapback]256658[/snapback]</div>
    Around here you need to be careful where gas is stored and how full the tank is. As you know water is everywhere around here.
  8. benighted
    530
    Westport, WA
    Yes water is everywhere here.
    I got it back on Monday, the bill ended up being $549.09.
    I'm going to be very careful what I put in there from now on!
  9. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(benighted @ May 27 2006, 08:38 PM) [snapback]261939[/snapback]</div>
    A BIG AMEN There Brother!!! It is wet out there!!
