Changing horn in 2016 Prius
Discussion in 'Gen 4 Prius Accessories and Modifications' started by booke02, Apr 16, 2016.
  1. booke02
    booke02 Active Member
    391
    415
    Israel
    There are numerous threads about changing the stock horns in a Gen 3 Prius with 74100 Fiamm El Grande.
    Has anyone tried doing this with a Gen 4 Prius?
    krmcg likes this.
  2. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    On a gen three I did, and when looking at the gen 4, there should be no problem. Plug and play
    On the gen 4, I put different horns
    On the drivers side I put a Stebel Nautilus Compact Twin Air Horn
    and on the passenger side the Stebel 11690058 - Nautilus Compact Truck Mini Air Horn
    In the gen 4 there's tons of room in there.
    Not plug an play at all, I had to make the brackets. Each horn need about 18 amps, so I tapped in at the battery with a 40 amp in line fuze, used two relays at each of the horns.
  3. glennonrp
    glennonrp Active Member
    178
    199
    Fontana, CA
    Four Touring
    JP, do you mean that the El Grande would be plug and play in the Gen 4?
  4. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Yes, no need for relays. The gen 4 horns have "length extensions" to assure that the horn output is directed to openings in the grill.
    Remove the extensions from the gen for horns and attach them to the el grande. Re-attach to car.
    glennonrp likes this.
  5. Prius_noob18888
    Prius_noob18888 Junior Member
    44
    39
    Singapore
    any owners used Hella supertones? Not sure if they are plug and play
    wat other P&P horns can be used on the Prius gen 4?
    #5 Prius_noob18888, Apr 26, 2016
  6. krmcg
    2,592
    2,392
    Whittier, CA
    Ordered today from Amazon. Will be another project for my long weekend.
  7. krmcg
    2,592
    2,392
    Whittier, CA
    Installed the horn(s). Only difficulty was the small amount of room in the front of the engine bay.
    The plastic cover came off easy - push the center of the clip to release. The horns were removed simply by unscrewing one bolt, which was easy to access. Each horn was connected to a single pull-off connector. Used the new brackets from the horns and re-used the bolt from the Toyota installation. One bolt installation and push-on connector. Sounds much better!
    vince22 and booke02 like this.
  8. jbkendrick
    jbkendrick Active Member
    232
    197
    Baltimore, MD
    Interested KRMCG. Is this louder and sound more like a standard American automobile horn, or something else. Also, can you supply a link for purchase. Thx, J
  9. krmcg
    2,592
    2,392
    Whittier, CA
    Yes, more like an american car
    jbkendrick likes this.
  10. booke02
    391
    415
    Israel
    You mean like a Ford Model T ???
  11. Mendel Leisk
    41,911
    I was wondering how long it would take before this thread would turn comical. :)
    booke02 likes this.
  12. vince22
    vince22 Active Member
    205
    249
    califorinia
    100% agree, I like the way it sounds, no more wimpy golf cart horn.
    krmcg likes this.
  13. jbkendrick
    232
    197
    Baltimore, MD
    Thanks KRMCG. J
    Terre likes this.
  14. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    What is the Amazon part number? Since it appears nobody can post links the part number would be next best thing. I need a nice loud horn, not the forklift sounding thing I have now.
  15. krmcg
    2,592
    2,392
    Whittier, CA
  16. thunderstruck
    154
    151
    Port Charlotte, FL
    2022 Prius
    I feel like a typical American driver, but I haven't even looked under the hood yet! Hope it's accessible from the top of the car since I'm way too fat to slide underneath.
    GoodOldBob likes this.
  17. krmcg
    2,592
    2,392
    Whittier, CA
    In front of the engine compartmentjust take the black plastic shield off first. Everything is from the top.
  18. PriUncut
    PriUncut Active Member
    268
    266
    Southern California
    Four Touring
    Me too!
    I did have someone cut me off the other day. Now, that's got me thinking about replacing it.
    To anyone who has replaced it... anyway to post an audio file of how your replacement sounds?
  19. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    There's a link in my signature below to a gen 3 thread about horn replacement. The OP put a video in the first post with a dual tone horn setup. Big difference in volume and tone from oem.
    GoodOldBob and PriUncut like this.
  20. PriUncut
    268
    266
    Southern California
    Four Touring
    Ohhh, THANK YOU... that does it. I am making that mod ASAP! Just had to use my horn again, today to wake up a driver asleep at a light change.
    So which one did you install...
    72102 FIAMM Freeway Blaster Horn High Tone
    72112 FIAMM Freeway Blaster Horn Low Tone
    or the 74100 FIAMM El Grande Twin Horns?
    I assume that's the "Low Tone" version in the video. Do we know? I guess should read the whole thread.
    Mahalo!!
