Speed Limiter Adjustment Down - Yes down....
Discussion in 'Gen 3 Prius Main Forum' started by Scrambler, Apr 19, 2016.
  1. Scrambler
    Scrambler Junior Member
    Dallas, TX
    I just purchased a 2011 Prius 3 for my 16 year old son and want to try to limit his top speed to 80mph. Does anyone know if that is something the dealer can do or if there is an aftermarket product anyone has used? Maybe for a fleet use?
    Thanks
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Don't know about that but there is a device that can be put on the car and you can read the cars speed history from you smart phone. Not a limiter, but a monitor. I'd let the kid know the monitor exists and if he tops eighty, he loses the car.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I suppose I'm very tempted to say...don't give him the "tool"--the vehicle, if you don't trust that he's educated and responsible enough to use it safely.
    Putting an 80 mph cap would accomplish what?
    Very deadly accidents can happen at 80 mph, and everywhere above and below that arbitrarily chosen limit.
    I don't mean to sound snarky, but if your son isn't ready to be trusted to drive safely and obey speed limits? Then maybe he's not ready for to be given the vehicle?
  4. Caniac
    Caniac Active Member
    232
    164
    Happy Valley
    80 is low for Dallas standards.
  5. Mendel Leisk
    41,814
    I don't like going over 80 kmh. :oops:
    drysider, FinToy, bisco and 1 other person like this.
  6. BZzap!
    BZzap! Senior Member
    1,607
    878
    Pertronics makes Rev Limiters that can be adjusted to just about any rpm. I'm not sure how the Prius engine management system would react to something like that but you can do some research.
  7. Mendel Leisk
    41,814
    Confusing kilometers per hour with revolutions per minute?
  8. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    A rev limiter on a Prius would certainly limit engine power output, but wouldn't limit the car to any specific speed unless we make specific assumptions about wind and grade---or lack thereof. Probably not a good idea, because it might unduly hamper responsible hill climbing or merging.
  9. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Theoretically, the Prius can reach its topspeed with the ICE limited to 2600 rpm. Lack of power will probably prevent it reaching it like that, except going downhill.
    To limit the car to 80 mph by limiting the rpm would mean a limit to 1325 rpm.
    On a flat road, the car will still be drivable if you keep under 2600 rpm, but not if you keep under 1325 rpm.
  10. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    80 ??? I don't think I ever hit that in the last 3.5 year .... it is not the prius but your son you need to limit.... :)
  11. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    I see your hypothetical point that that low engine speed (or even slower, by my calculations) would allow up to 80 mph without overspeeding MG1. However, aerodynamic drag would make 80 mph at 1325 rpm highly improbable except down hill.
    According to Toyota's BSFC chart, the car needs 2200 RPM to maintain 120 km/hr [74.6 mph] (under unstated conditions, which I'd assume include a level road).
