Higher viscosity oil for motorway driving
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by drives, Apr 22, 2016.
  1. drives
    drives Junior Member
    48
    Hampshire, U.K.
    I know the topic of what oil to use has been done to death, but I bought my Prius a few months back to do around 90-95% motorway driving at 70mph for my commute to work. I did an oil change when I bought it and used Motul 0w20 (not much choice with 0w20 oils in the UK), but read in the manual that it says a higher operating temp viscosity may be better suited to high speeds.
    Now the alternative from the manual is 5w30, but am thinking of going with a 0w30 oil such as Motul Eco-nergy. I can't find any reason not to use 0w30 above 5w30, other than it doesn't specify it in the manual..
    Anyone use 0w30 or see any drawbacks? Hardly any info on using this oil in the Prius, presumably because it's not specified in the manual.
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The oil cap has 0w20 molded onto it. The US manual says that if 5w20 is used, switch back to 0w20 at the next change. So they seem very keen to use only the 0w20 oil.
  3. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    5w30 or 0w30 would be fine.
    *edit* The only negative is that you "might" see gas mileage drop slightly. I used Mobil 1 5w30 synthetic in mine for a couple of changes and I saw no difference in fuel consumption.
    #3 Maroon, Apr 22, 2016
    tankyuong likes this.
  4. drives
    48
    Hampshire, U.K.
    Thanks will probably go for 0w30 then as presumably this will be slightly better than 5w30 for cold starts (and cost difference isn't that much). I realise 0w20 is the main grade of oil recommended but Toyota do specifically recommend higher viscosity for high speed (presumably motorway) driving.
    orenji likes this.
  5. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    The USA owner's manual offers a similar suggestion, which they make as vague as they possibly can.
  6. Former Member 68813
    3,524
    983
    US
    yes, due to CAFE.
    see above.
    non-CAFE countries allow for 0W20 all the way up to 20W50.
    orenji likes this.
  7. Mendel Leisk
    41,818
    ^ Australia for one. There the Owner's Manual shows a complete gamut of oil grades, IIRC.
  8. Toppcat
    Toppcat Member
    223
    69
    Northern California
    I don't think there be much gain using 0-30 maybe a slight decrease in mpg! If your not encountering extreme driving condition such as extreme heat,towing, racing, don't see a call to switch! BTW. Good chance it will effect your emission reading too!
  9. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    The other thing you might want to look for is ACEA A1/B1 rating which is hard to find in 0W-20 but you might find that in 0W-30 grade. I am not the expert, but that highest rating apparently goes to formulations which resist breakdown over time in the engine. The Toyota stuff seems quite good quality.
  10. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    why would that be?
  11. Rebound
    3,996
    2,645
    Portland, OR
    The larger number indicates a higher viscosity. In cold weather, and when starting the engine, a thinner oil will ease starting and flow more freely.
    But, when the engine is hot, especially if you drive a constant 70 MPH, you want a thicker oil that will continue to stick to the engine parts and provide lubrication. Hence the reason to use a 0w40 instead of a 0w20.
    But, the 0w40, being thicker, will probably reduce mileage, as the engine needs to work harder to splash the rods and crank through the thicker crankcase oil. This in turn may slightly affect emissions. But, it may be better for a car that's routinely driven at high speeds.
    Coast Cruiser likes this.
  12. StarCaller
    1,279
    730
    yeah, but he says it'll affect the "emission reading"/
    meaning, like when you go to the smog test & they put a probe in the exhaust, the readings will be different than with the 0w-20 oil/
    that's what I don't understand/
    from my understanding it shouldn't affect this numbers at all/
  13. Mendel Leisk
    41,818
    I wonder about Toyota's motivation to specify 0W20, if it's basically to wring a bit more mpg, and engine longevity may suffer. Not sure though. Talking myself into something, lol.
    scona and Coast Cruiser like this.
  14. drives
    48
    Hampshire, U.K.
    This is basically what I was wondering, but I guess there's no definitive answer
  15. Former Member 68813
    3,524
    983
    US
    LOL, read between the lines. have they ever claimed it increased engine longevity (besides cold start)?
  16. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    Looks like some of those benefits can be attributed to better quality/additized lube oil, as opposed to viscosity specs. I actually do feel the Toyota brand oil is among the best quality, at least from the specs folks have posted here in the past.
    I do feel there was a change in piston tolerance between Gen2 and Gen3, as engines are getting tighter. Gen2 reportedly had the tendency to pick up ~2% fuel blow-by in the oil, so I do not like to go down to 20 weight for Gen2. Gen2 we have 5k drain interval.
    I almost picked up 6 quart of 5W-20 from an Oregon Gen3 Prius Chatter, so adverse to use it, is he. But I did not want to stuff it in my suit case for the flight back home.
    #16 wjtracy, Apr 23, 2016
  17. StarCaller
    1,279
    730
    that's from the australian user manual /
    so obviously it's not going to hurt the engine using a heavier oil /
    BION
    StarCaller
    orenji, kkmestrada and Coast Cruiser like this.
  18. Former Member 68813
    3,524
    983
    US
    unless you use it in too cold weather for cold starts.
    in case of prius, at least the US and overseas advice overlaps (ie 0W20 is OK in most all condition). I have an engine in another toyota car where the US spec is 5W30 while overseas spec 5W30 only acceptable in winter and 10W30 or heavier is to be used in summer temps. as soon as i learned that, i started using 10W30. sadly, dealer used 5W20 a couple of times under warranty and they argued it was backspaced, (it never was). BTW, the engine developed a funny noise (when cold) after those 5W20.
    #18 Former Member 68813, Apr 23, 2016
  19. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    In my area, where we have no winter it seems, I would actually feel a little more comfortable with 0W-30 or 5W-30 synthetic. But what the heck do I know.
    orenji and wjtracy like this.
  20. StarCaller
    1,279
    730
    since my first oil change at 1500 miles I use mobil1 0w-40/
    my average at 38.000 miles is around 52mpg/
    BION
    StarCaller
    m.wynn, orenji, Maroon and 1 other person like this.
