How to turn off display during daytime?
Discussion in 'Gen 3 Prius Main Forum' started by PriusCatMouse, Apr 26, 2016.
  1. PriusCatMouse
    PriusCatMouse Junior Member
    31
    How do I turn off the display (speedo/HSI area) during the daytime?
    I can use the wheel to dim during the daytime but can only dim can't turn off the display like I can at night. I've tried turning the lights on and adjusting the wheel but sill can turn off all the way.
    I would like to turn it off and just use the HUD.
    2013 Prius Four
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I don't believe it's possible.
  3. qdllc
    qdllc Senior Member
    1,377
    400
    The dimmer is to affect brightness at night and when it dims during the day. It never turns "off." That'd be a safety issue.
  4. PriusCatMouse
    31
    Oh ok thank you. And what would be the safety issue?
  5. bisco
    52,395
    you can't read your speed.
  6. PriusCatMouse
    31
    I think he missed my last sentence states I have the HUD otherwise I wouldn't be trying to turn off the display.
    Either way case closed since I don't have the option to turn it off during the daytime. Thank you all
  7. qdllc
    qdllc Senior Member
    1,377
    400
    As the HUD isn't standard equipment, I suppose Toyota saw no point in having an "off" option on the dash as it would have to be designed for only two trim levels that have the HUD.
  8. PriusCatMouse
    31
    That's correct this determination has already been made.
    It's cool not a big deal at all :)
  9. Mendel Leisk
    41,911
    I can recall soon after we got our 3rd gen, driving in brilliant sunlight, in melting snow wet roads: good luck trying to read the cathode tube display, even cranked up to full brightness.
  10. qdllc
    qdllc Senior Member
    1,377
    400
    Hey, at this point the thread is getting a life of it's own. It's FRANKENTHREAD! :eek::LOL:
