On models with no spare tire, what are folks doing?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by dpbsmith4, Apr 21, 2016.
Tags:
  1. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    I don't understand why a spare donut for Toyota's I'm seeing are 16"? Thought they'd be 15?
    LG-H901 ?
    ETP likes this.
  2. Mendel Leisk
    41,218
    More steel, less rubber?
    ETP likes this.
  3. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    You should avoid northern Maine in the wintertime.
    alanclarkeau likes this.
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I'd be careful mixing different sized rims on the same axle, since doing so might confuse the car's computers and they'll start flagging ABS errors etc etc... (just sayin'...)
  5. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    If the circumference is identical to the other tires how would the computers know the rim size is different?
  6. WilDavis
    2,493
    2,155
    49
    ...well, God would know...
    JohnF likes this.
  7. Mendel Leisk
    41,218
    It can't be much of a factor: using the temp spare does that.
    Frederickdawg likes this.
  8. Frederickdawg
    596
    335
    The Toyota corolla space saver saver wheel unused on my local Craig's list is specified  T135/80R16.
    This will work right ? In gonna offer $50 for it. Keep it in my truck or wife's Prius just in case.
    LG-H901 ?
  9. Mendel Leisk
    41,218
    That's the spec showing in my 2010 Prius Owner's Manual, should be good. I would take the plunge, get it, and then trial install, even drive up/down the driveway, just for giggles.
    ETP and Frederickdawg like this.
  10. Frederickdawg
    596
    335
    Or use it for tire rotation purposes. Lol.
    LG-H901 ?
  11. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    And measure its circumference and the circumference of one of your regular tires.
    ETP likes this.
  12. Mendel Leisk
    41,218
    I think the temp spares are slightly smaller OD, say 1/4".
    ETP likes this.
  13. Frederickdawg
    596
    335
    The guy wouldn't entertain $50. So spent the money and ordered Carista instead LOL
    LG-H901 ?
  14. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Pretty simple to take the mounted and inflated tires and run a tape around them. Then you know for sure, and can easily figure the % difference if they are not the same.
    ETP likes this.
  15. Mendel Leisk
    41,218
    I fed it into my spreadsheet some time back. Theoretical value, but should be close.
    Frederickdawg and ETP like this.
  16. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Agreed, but as a scientist I like to measure things to check theoretical calculations, especially when it's easy to do so.
    ETP likes this.
  17. Mendel Leisk
    41,218
    You knew that was red flag to a bull, didn't you?
    Anyway, couldn't find a flexible fabric tape long enough, and regular steel tapes were kinking/protesting, so I ended up using a thickish nylon rope. The subjects were a 195/65R15 X-Ice with near-new tread, and my Prius temp spare 135/80D16. My wife helped position the rope, making sure it was on the crest and not slipping into a groove.
    Anyway, in both cases the rope measured 79.25". Now this is going around the centroid of the rope, outside of the tire OD, so a bit greater than the actual OD, but what shakes out is that they're the same, as near as I could measure.
    I also stacked one atop the other, on a concrete slab, pushed a square against one side and aligned them, then checked the other side: also aligned.
    (perspective at work here, they're actually near identical OD)
    Close up:
    #37 Mendel Leisk, May 3, 2016
    epoch_time, Frederickdawg and ETP like this.
  18. ETP
    2,802
    1,170
    Auburdale FL
    Love paper maps BTW.
  19. bisco
    51,785
    they definitely have their place when it comes to the big picture.(y)
    ETP likes this.
  20. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Nice work! Isn't research fun? Your wife is a gem, but I suppose you knew that already.
