37 mpg thus far
Discussion in 'Prius v Fuel Economy' started by PanthersFan, May 9, 2016.
  1. PanthersFan
    PanthersFan Junior Member
    55
    17
    South Florida
    2013 Prius v wagon
    The Avg MPG display in the car reads 40 and change but I'm getting 37 by my own calculations. I'm happy with this but there's room for improvement. I drive for fuel economy and my wife just drives as she would any other car. We also use the a/c virtually every time we're in the car (South Florida and a toddler whom we cannot hear with the windows down).
  2. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    As the toddler gets older, you'll tend to roll the windows down more often.
  3. bisco
    52,093
    pump up your tyres and practice pulse and glide. isn't there a window lockout?
  4. PanthersFan
    55
    17
    South Florida
    2013 Prius v wagon
    My tires are at 43/41. I do a lot of gliding and eco driving.
  5. bisco
    52,093
    keep up the good work!(y)
  6. PanthersFan
    55
    17
    South Florida
    2013 Prius v wagon
    Tires are Bridgestone Turanza EL400. Probably not the best tires, eh? They came with the car and still have a good amount of tread life. I'll go with LRR tires when the tire comes for replacement. Thinking about Ecopias.
  7. bisco
    52,093
    if they are oem, they are usually better at mpg's than anything else. most people complain after tyre replacement.
  8. PanthersFan
    55
    17
    South Florida
    2013 Prius v wagon
    I assume they're OEM because I bought the car with 25K miles.
  9. Toppcat
    Toppcat Member
    223
    69
    Northern California
    37 mpg is good numbers for a v ! I don't use eco mode in city only for freeway other wise ya piss off other drivers! Beside gas is cheap! My truck get 7-12 mpg when gas was $5.00 + per gal over $250.00 a tank that gives me about 200 miles
    PanthersFan likes this.
  10. PanthersFan
    55
    17
    South Florida
    2013 Prius v wagon
    I should mention I drive only in Normal mode. I ditched Eco mode a while back in favor of better throttle control and climate control.
  11. Mendel Leisk
    41,643
    Switching off ECO shouldn't be a factor. Your tires may be Low Rolling Resistance, I'm not that up on Prius v tire sizes, and there's one size that has 2 versions, one IS LRR. Check here:
    Bridgestone Turanza EL400-02
