IN CABIN LED SWAP A MUST (photo)
Discussion in 'Gen 4 Prius Accessories and Modifications' started by DBLXX, May 5, 2016.
  1. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    OK - I bought the box of LED's to change the map lights but they also fit the lights at the bottom of both drivers and passenger front doors and the light in the trunk.
    This is a MUST DO for people who use their car often at night.
    Bought these on Amazon for $13 bucks for a box of 10.
    Weasle543 and krmcg like this.
  2. emj1s
    emj1s Junior Member
    US
    Do you have the Amazon link?
    LG-H900 ?
  3. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    Nice. I have my reverse and stop lights converted to LED and am HID conversion. LEDs rock!
    XT1585 ?
  4. bowerda47
    bowerda47 Member
    34
    65
    Michigan
    Three Touring
    [/QUOTE]
    I'm a clutz. How hard is it to replace interior bulbs? What tools?
  5. kevindb
    kevindb Junior Member
    Baltimore, MD
    Why are they a "MUST DO for people who use their car often at night"? Are they much brighter than the stock bulbs?
    I have noticed that the lighting in the rear cargo area is 'insufficient' at night.
    ETP and krmcg like this.
  6. bowerda47
    bowerda47 Member
    34
    65
    Michigan
    Three Touring
    Changed the hatch and front door courtesy lights to LED. Only problem is every time the led in the hatch comes on my Mogwai screams "Bright Light, Bright Light" LOL
  7. ETP
    2,804
    1,170
    Auburdale FL
    Wonder if the Touring loaded version has LEDs inside?
  8. Weasle543
    Weasle543 Member
    55
    Ohio
    I used the same Yorkim's for the map, lower driver & passenger door, and both vanity mirror lights. Much whiter than the OEM incandescent lights.
    The rear seat dome light bulb needed a different bulb. Bulb size: festoon T10x31. I bought Circuit Performance 6000K Superwhite LED Festoon T10x31 Bulbs from Amazon, just under $15.
    Couldn't find any light in the hatch area (trunk)...
    Lucifer likes this.
  9. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    Be careful with the wattage. LEDs still get hot. You don't want to melt the light housing, I have see it happen a whole bunch.
    XT1585 ?
  10. DGuy21
    DGuy21 Member
    Lansing, MI
    Three Touring
    As long as you match up the replacement LEDs with the correct wattage of the bulbs you are pulling out you should be good. We used to replace interior lights all the time(not in a Prius but many of cars) and I can not say I remember running into a heat issue.
    tony2ltr likes this.
