LED low beam headlight bulb replacements
Discussion in 'Gen 3 Prius Accessories and Modifications' started by michristi, May 15, 2016.
  1. michristi
    michristi Junior Member
    So Cal
    Are there any good reliable LED low beam headlight replacements bulbs now that we are in 2016? I'm looking for Easy-to-install Plug-n-Play connections to replace OEM bulb.
    I'm also interested in replacing my backup bulb to LEDs.
    TIA!
  2. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    Easy answer. No.
    iPhone ?
    Vman455 likes this.
  3. Friend of Bill W.
    109
    164
    Elkhart, IN
    Not true. There are plenty of plug and play leds and I've used them in several of my vehicles and they are extremely underrated because they seem too simple. Here's some I use.
    Merged.
    Well it's not letting me post pics. Go to ebay and type in samsung h11 low beam prius. 30 bucks a set.
    #3 Friend of Bill W., May 15, 2016
  4. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    I'm looking at the LED headlight parts on E-Bay, and they all have clusters of LEDs. The headlight projector beam optics probably require more of a point-source (the bulbs have a small filament), so I would think the LED lights would result in a less-bright, more-diffuse headlight pattern.
    Have you noticed this?
  5. Friend of Bill W.
    109
    164
    Elkhart, IN
    I've not noticed any difference in strength or projection. They actually work very well and keeps it simple.
  6. xliderider
    xliderider Senior Member
    8,056
    3,224
    Honolulu, HI
    How about the "cateye" effect, where there is no light projected directly in front of the projector lens? This appears like a cateye, or more correctly, like the vertical irises (slit) of a cat's eye, showing up as a dark vertical line when looking directly straight on at the projector lens.
    This happens due to the side mounted LEDs with a circuit board in the middle, blocking the light from each side, producing a dark area immediately in front of the "bulb".
  7. Friend of Bill W.
    109
    164
    Elkhart, IN
    It'll be dark in 15 min I'll go snap some pics
  8. Friend of Bill W.
    109
    164
    Elkhart, IN
    UPDATE!!! Gotta eat my words here, just turned the headlights on and they are now very dim. When I first installed them just 2 days ago they were fine, now they are VERY dim. Don't buy these.
  9. xliderider
    8,056
    3,224
    Honolulu, HI
    Car in Ready Mode? In Ready Mode, the voltage is about 14.4v, vs 12.x volts off the auxiliary battery when the car is Off.
  10. Friend of Bill W.
    109
    164
    Elkhart, IN
    Nope I had the car running and drove down the street. I was shocked because these were bright when I first installed them. My led parking lights are brighter than these. Not sure what happened, tomorrow I'll put my stock bulbs back in. 30 down the drain
  11. Friend of Bill W.
    109
    164
    Elkhart, IN
    1463366981253.jpg 1463366992861.jpg the first pic is of the low beams fully on. Second pic is of just set to parking lights. As you can see my parking lights alone are brighter than these low beam leds
  12. A.Reyes
    270
    178
    Beaufort, 29902
    Justification to my answer.
    OEM LEDs are simply the best LEDs on the market. There is a person on the boards who retrofitted the corollas LEDs on his Prius and still said they weren't as bright as HIDs, but are better than the stock halogens.
    All the LEDs kits I've seen just aren't up to par with with a retrofit LED.
    It's simple. Get an HID kit and install that. Even you want install the relay harness too.
    iPhone ?
    PriiPrii likes this.
  13. Friend of Bill W.
    109
    164
    Elkhart, IN
    Pardon my ignorance, what is retrofit?
  14. A.Reyes
    270
    178
    Beaufort, 29902
    When you actually change out then projector itself. It's a bit of a process. Removal of the headlight from the car, putting it in an oven(literally) and opening the headlight to changed everything out. Depending on the application it may require cutting and trimming on the projector and/or housing itself.
    I have done an H1 retrofit. I used h1 projectors in my car rather than the standard H11.....or H9...I forgot. Hahaha.
    iPhone ?
    Friend of Bill W. likes this.
  15. Friend of Bill W.
    109
    164
    Elkhart, IN
    Ah that makes sense....but waaaay too much work for me! Lol
  16. A.Reyes
    270
    178
    Beaufort, 29902
  17. pauerbach
    pauerbach Member
    101
    34
    Simply put: no
    There are plenty of aftermarket LEDs on the market but they're all gimmicks and I feel for the poor saps who buy them with high hopes. The Prius' projector headlights (like all projector lights) require a properly focused point source of light shining in just the right way. None of these aftermarket products will have a useful beam pattern for nighttime driving.
    xliderider likes this.
  18. TexAmi
    TexAmi Junior Member
    Correct me if I am wrong but don't they make h11 halogen bulbs with more output?
    If so does anyone know of a replacement from a notable company... like philips Sylvania or ....?
    I just realized I could get a ticket for anything over 65w/55w high/low beam. Is that true?
    If so then we can upgrade from the standard 35w to 65w. I just hope the wires don't over heat
    #18 TexAmi, May 25, 2016
  19. Vman455
    Vman455 Senior Member
    538
    554
    The Middle
    That was me. The Corolla LEDs are as bright, but aren't quite as wide as most OEM HID beams, but have better distance lighting.
    Something to keep in mind: if Toyota could just drop in LED bulbs in halogen housings for a few bucks, would they spend the extra money on proprietary (expensive) LED headlights for the Corolla, Prius, etc.?
    Night shot:
  20. FinToy
    FinToy Active Member
    145
    141
    Finland
    Comparing the above picture against factory LED lights:
