Visual Tables of Gen4 Package Combinations
Discussion in 'Gen 4 Prius Main Forum' started by TonyPSchaefer, Nov 18, 2015.
  1. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    Why wasn't this feature offered across the line? Ditto the Eco's higher pressure extra low rolling resistance tires?
  2. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    Did your dealer do that? Think mine would too. Wouldn't mind the softex myself but likely my dealer would likely offer real leather too with the heated front seats. I could live without either but if you can get them on a Two Eco, why not?
  3. Tideland Prius
    16,610
    Cost? But it's been mentioned a few times since I've said that, that the IR windshield isn't mentioned in the literature in US models so it may not have made the journey across.
    Also, higher pressures = rougher ride. I think Toyota is expecting hardcore PriusChatters (and other hypermilers) to go with the Eco model and they know we tend to increase our tire pressure. For the general public, the lower tire pressures are fine because they balance fuel economy, wear and ride comfort.
  4. galownia
    galownia Previous master neon mechanic
    117
    73
    I did it through the dealer on the first car. On the second car, I went straight to the aftermarket supplier used by the dealer. Saved ~$300. However, the aftermarket supplier said they would not have given me that price had they not known me from the first car.
    Jonathan
  5. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    Thanks!
  6. Dragon Rider
    Dragon Rider Active Member
    344
    212
    Miami
    Hello , I just Got my Prius Eco Two last week. Does anyone have any information on how to get the Fog Light . Thx
  7. Tideland Prius
    16,610
    There's a discussion here if you would like to check it out.
    Fog Lights for Trim 4 | PriusChat
    TonyPSchaefer and krmcg like this.
  8. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Thanks, Dude! Like Emilio, I'm thinking of getting a Four and adding fog lights. Not sure how I missed that thread.
    Tideland Prius and DonD like this.
  9. Tideland Prius
    16,610
    No Prime Time for @TonyPSchaefer?
  10. TonyPSchaefer
    14,816
    2,501
    66
    (1-car garage) + (1 wife) = no garage for Tony.
    Not only is it ill-advised to use extension cords when charging, I'm simply not going to run a cord outside. Especially not when it's sub-zero. The condo HOA would never allow me to build an outdoor plug-in next to my driveway. So no; no garage, no plug-in.
  11. Tideland Prius
    16,610
    :( I see. Makes sense.
  12. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I was (almost) positive the Three Touring has SofTex seats?
    And my basic Three model has an adjustment in the settings for the headlamps auto-off timer.
    (Maybe these items have already been corrected in the post?)
  13. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    Wonder if the car settings on the head unit are replicated on after market units. I've seen threads where folks installed such units and have wondered about the car specific apps and settings.
  14. Vasu Sreekak
    Vasu Sreekak New Member
    New Hampshire
    Even the sales people at the dealerships are not able to explain this clearly - They are hiding behind "You know more than I do" OR Let's check together. How shameful...
  15. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    Just shows how useless many dealers are.
  16. farmecologist
    farmecologist Senior Member
    1,960
    1,799
    Southern MN
  17. TonyPSchaefer
    14,816
    2,501
    66
    #297 TonyPSchaefer, May 23, 2017
    Tideland Prius and farmecologist like this.
  18. Tideland Prius
    16,610
    Toyota.com lists the One as 3,075 lbs as well (it's probably a few pounds lighter with the missing items but I guess they didn't bother relisting it since it falls in the same EPA category. Plus, it appears they still is the "starting at" price as the Two).
    TSS-P info didn't save, @TonyPSchaefer . It still shows optional for Three & Four.
    RCO likes this.
  19. Tour de Prius
    Tour de Prius New Member
    Michigan
    Three Touring
    Just an update to this visual table, the three touring does not come with and power seat at all. Still manual. Power seat only comes on the four touring. Found that out at the dealership last night.
  20. ETP
    2,803
    1,170
    Auburdale FL
    Seems my auto stop and collision warning system is working very well these days since I adjusted the sensitivity to max distance.
    Either that or I am becoming a road hazard, TBD
    RCO likes this.
