Oil Consumption Issues - Thinking to switch to 5W-40 need advice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by iodenise, May 17, 2016.
  1. iodenise
    iodenise New Member
    Los Angeles
    Hello,
    I own a 2009 Prius with 130,000 miles on it.
    Last year, after i had to leave the car parked in the California desert, I started experiencing issues with the oil consumption in the car. My Prius currently requires regular 5W-30 motor oil (non synthetic).
    The mechanics can't notice any issue with the system, no leaks; and I do not see any loss of oil on the ground. But every time I change my oil (which I regularly do at 3,000 miles) they told me it's low in level (it consumes about half of it) and dirty.
    My dad was suggesting to changing to a 5W-40 because more viscous and should evaporate less. He lives in Europe and over there is a very common oil, and many prefer it to the 5W-30.
    You'd think it also makes sense since I live in Southern California, and it is an oil that performs better with high temperatures.
    However, when I requested to try that change at PepBoys last month, they wanted to eat me alive and told me I would have just ruined my car and engine and would not have been able to switch back to 5w 30 and my car would have made a bunch of noise. Sounds like a bunch of BS to me, but then again I am not a mechanic.
    So I had them service the car with regular 5W-30...
    But is 5W-40 really that bad? They seem to be very similar oils and from the initial research I have done the worse it can happen seem to be a slight loss in fuel efficiency.
    Anyone able to chime in? Or experiencing same issues?
    I am really trying to avoid dropping $2k on taking the engine out to figure out what's causing it (the car is probably worth $6K now) - and this oil issue is the only issue this car has been showing.
    Everything else is awesome! Any help is truly appreciated.
    Thanks!
    Denise
    maleko and ETP like this.
  2. Former Member 68813
    3,524
    983
    US
    congrats, you're smarter than the pepboys idiots. 5w40 or even 15w40 is fine for south california. but even more important is checking oil at every fueling and adding oil to the full line. any oil is much better than no oil.
    ETP likes this.
  3. CR94
    CR94 Senior Member
    2,676
    1,159
    Northwestern S.C.
    Your analysis of the advice you got from the boys at Pep Boys is about right. However, I'm afraid 5W-40 wouldn't reduce consumption more than slightly. You could try it---or 10W-30 or 0W-40 or something else, but it won't matter much.
    By "consumes about half of it" between your 3000-mile oil changes, do you mean using half of all the oil in the engine, or halfway down from the full to the low mark on the dipstick? The latter wouldn't be so bad. Just add as necessary to keep the level between the marks.
    ETP and tvpierce like this.
  4. Former Member 68813
    3,524
    983
    US
    how do you know? have you tried?
    ETP likes this.
  5. bisco
    51,539
    welcome to priuschat! agree with the above, learn to check your oil level and figure out how much you are actually burning. also, there is no way to tell if the oil is 'dirty' without an analysis. just because it goes in clear and comes out brown doesn't mean anything. all the best!(y)
    ETP likes this.
  6. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    As long as the oil consumption isn't more than a quart every 1000 miles you shouldn't worry about replacing the gas
    engine just yet. Some engines burn oil, some don't. You lost the lottery.
    What you do need to do is monitor the oil level and top off as needed. I know it's a pain to check the level after every two fill ups but you can still buy a lot of motor oil for $2000.
    ETP likes this.
  7. Mendel Leisk
    40,986
    Does moderate to high oil consumption leaded to failed catalytic converters? Just curious.
    ETP likes this.
  8. jadziasman
    1,355
    488
    District 6
    Once the oil consumption reaches 1 qt every 500 miles, yes. iodenise isn't close to that bad of consumption, yet.
    There was a Priuschat member who had horrendous oil consumption with his Prius but his screen name eludes me
    at the moment. He had over 200K miles on his, maybe more. Don't remember. Too forgetful (and old).
    ETP and Mendel Leisk like this.
  9. tvpierce
    tvpierce Senior Member
    951
    882
    Maine
    2013 Prius v wagon
    ETP likes this.
  10. ETP
    2,802
    1,170
    Auburdale FL
    0W40 may be worth a try next time. Or 5W30. Are you sure it isn't a 5W20 requirement for your car.
    #10 ETP, May 18, 2016
  11. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Sounds like Pepboys doesn't carry 5w40 bulk for oil changes and didn't want to open ones from inside the store. There aren't a lot of cars that spec that weight. As others have said move up to higher weight oil and see if it helps.
    I'd probably keep topping off the car instead of repairing it. Unless you do the repair yourself, the math to do the repair wouldn't make sense unless consumption were really high. Say it costs $200 to fix whatever. Well that's 100 quarts of oil. That could go a long ways and something else on the car would break before then.
    ETP likes this.
  12. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    I am assuming the "mechanics" are the Pepboys folks? "Low" can mean different things to different people, and without a quantitative measure, all of us are just taking shots in the dark. My *guess* is that the oil is on the low end of the range by the time you get your oil changed. The top end of the range on the dipstick is about 3.9 quarts, the bottom end is about 3 quarts. So, if you are reading on the bottom end and you filled up to the top line, then you are burning about a quart in 3,000 miles. That is not outrageous. Some Prii don't burn any, some burn as much as yours, but either condition is considered to be "normal." I can't remember exactly off the top of my head, but I think Toyota only considers it an issue if you're burning more than 1 quart per 1,000 miles.
    I don't have any hard numbers to back up this claim, but I think you are very unlikely to see significant improvements by switching to a more viscous oil. You may go from buying 1 quart every 3,000 to burning 0.9 quarts every 3,000 (again, numbers made up), but I doubt the difference will be significant enough to justify the switch. Either way, if you wanted to, you can make the switch for an oil change safely. You can go from 5w-30 to 5w-40 and back again, no problems.
    TL;DR
    1. Check your oil levels yourself. If you are within the fill lines, you are not "low."
    2. You can switch to 5w-40 without blowing up your car. It will be fine, but I doubt the improvement in oil consumption will be significant.
    ETP likes this.
  13. ETP
    2,802
    1,170
    Auburdale FL
    The technology of synthetic oil. How is synthetic oil made?
    Nothing to loose but going up little. I would not over do it. 5W30 and 0W40 is worth a shot in hot climates.
    Remember a hybrid needs low turn over start viscosity all the time. It needs the lower number for easy engine turn over.
