How to replace your Gen 3 spoiler, step-by-step with pictures
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ualdriver, Dec 14, 2015.
  1. ualdriver
    ualdriver Member
    358
    65
    Midwest US
    I just replaced the spoiler on my 2012 Prius Plug-in (Gen 3 Prius), and it wasn't too bad a job. I took some pictures as I went along and created a step-by-step as it appears shearing the spoiler off is not that uncommon and I couldn't find anything on the forum in one place that explained how to do the repair. Hopefully it helps someone...
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Nicely written, clear and detailed photos, Thanks a lot.
    Leonardo Martinez and ualdriver like this.
  3. arescec
    arescec Active Member
    238
    105
    Croatia
    Just be careful when using metal tools like those grippers near to glass surfaces, best to cover them with blankets or something similar. Learned it the hard way when I just nicked the front glass and it fell apart, 1700$ :D (covered by insurance)
    Tim Jones and ualdriver like this.
  4. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    Thanks for all the effort you put into this. Good to know if we ever need it.
    ualdriver likes this.
  5. Mendel Leisk
    41,865
    You da man!
  6. bisco
    52,354
    great write up u/d, thank you! (well played on she who must not be named:cool:)
  7. Mendel Leisk
    41,865
    In my case, I'm "she". Hit it maybe three times, so far... :sick:
  8. bisco
    52,354
    same here.:oops: luckily, haven't ripped it off yet.:whistle:
  9. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
  10. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Great post, wealth of information. (y)
    Really should be made a sticky.
    milkman44 and Mendel Leisk like this.
  11. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    Great explanation, well done! Yet another reason the people on this forum are great.
    This did happen to me on my 2010, backed out of the garage with the hatch up. Errrr. Had a body shop do the job at the time.
    I am going to use your instructions to remove the rear panels and spray the metal cavities with Boom Mat spray for sound deadening.
  12. Currahee
    Currahee Member
    103
    34
    CT
  13. Currahee
    Currahee Member
    103
    34
    CT
    I just did this repair with a used spoiler and it was nearly impossible to fully pop in both plastic rivets on either side, but the bolts are torqued down pretty well. The 'newer' spoiler was also missing a gasket on the wire hole and a bit of water got in when I went through the car wash. Added some electrical putty to the hole, so we'll see how that works out.
    Currawong likes this.
  14. bisbonian
    bisbonian Junior Member
    Thanks for putting this up. My spoiler is held on by the third brake light wire right now so I've been mulling my options.
    This thread has made my options much clearer and I'm just ordered a new spoiler ($320 including shipping).
  15. faffer
    faffer New Member
    asdf
    2014 Prius Plug-in
    Having done this maybe a year before you posted it, thanks for putting it all in one place. However for me it was not as simple as bolting it on. The single layer of aluminum it bolts to was bent and the seals near the ends that are only held against the sheet metal by the force of the pushpins leaked slightly after going through a car wash. I had to take it to a body shop to get the metal straightened. It was pretty obvious after installing that the angle of the spoiler was different than before and comparing it with other Priuses in the neighborhood confirmed it.
    My other advice is that you can hold down the hatch by putting a rope through the metal loop that's part of the latch and looping it under your foot or through the cargo tie down loops in the tailgate area.
    Finally when I was searching for info on this repair there seemed to be a huge debate here on whether the spoiler is painted or just glossy plastic. Yes, it's painted. My replacement had a piece of masking tape on the back that was painted black and when I peeled it off there was gray plastic underneath.
  16. JanJ
    JanJ Junior Member
    Hi UALDRIVER
    Nice Instructions ~ just sheared our spoiler ~ WHERE did you get the painted one? Regards, JanJ
  17. ualdriver
    ualdriver Member
    358
    65
    Midwest US
    The name of the place is in the instructions. Don't remember off the top of my head. It came glossy black, no paint needed.
  18. JanJ
    JanJ Junior Member
    THANK YOU ~ the task of replacing the spoiler was accomplished in about 5 hours ~ working alone and at my relaxed pace. Replacement also came black, that matched well with the dark blue of our Prius ~ so no paint brush used :) Cheers, J in Michigan
    #18 JanJ, Apr 17, 2018
  19. Stangar
    Stangar Active Member
    174
    174
    Palmdale, CA
    Thanks very much for the in depth writeup. Saved me some green. My question is how the heck do you get the wiring back in place? I've wrapped some speaker wire around the wiring to the third brake light and still cannot pull the connector through. I'm using factory parts. Not sure what to do next. I know I don't want to pull on the connector.
    Any further helpful tips to thread the wiring through the spoiler?
  20. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Glad I'm not the only one that's been exploring under the spoiler. Wife tried to back out of the garage with hatch up. It pulled all the bolts loose from the spoiler. I took the bolts out as shown in the picture above and used JB Weld to put the bolts back in the spoiler. I was in a hurry and didn't let the JB cure enough and one end came loose. I took it apart again and cleaned it up and reglued it with JB and let it cure overnight. A few days later, I noticed the right end had loosened up so I made two thin metal brackets and attached them to the outer end of the spoiler. The spoiler is now solid, will try to post a picture.
    Raytheeagle likes this.
