Rusted scrape on roof
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ehand88, May 19, 2016.
  1. ehand88
    ehand88 Junior Member
    Birmingham, AL
    2014 Prius v wagon
    I just recently bought a 2014 Prius v and it has a scrape/dent on the roof that has some rust (I knew about it going into the purchase). I was quoted around $700 to get it repaired, but I am wondering how difficult it might be for me to fix it on my own. My reasoning is that this vehicle is going to be used for road trips and car camping, in addition to being my daily driver, so I expect that it will get fairly dinged up over the course of my ownership. I'm not super concerned about the dent, mainly just the rust. So if possible, I'm hoping to save some money on the repair and just remove the rust and paint the effected area. Also, with it being on the roof it's not something that stands out that much so I'm not looking for the perfect visual repair. Pics below:
    Thanks for your input!
  2. rjparker
    7,918
    4,680
    You just sand the rust off, apply a spray primer and then matcing spray paint followed by a spray of clear coat. It will look bad. 700 is a decent price for a seamless repair and entire panel refinish.
  3. ehand88
    Birmingham, AL
    2014 Prius v wagon
    I appreciate the input. Like I said, I'm not too concerned with the look I just don't want the rust to get worse. I haven't ruled out the professional repair, I would eventually want to get it taken care of that way. I can't say how recent the damage is, but I will be going on a long 2 week road trip at the end of June. Do you think there would be any harm in waiting until after the trip to get it professionally repaired?
  4. Mendel Leisk
    38,649
    I'd always go to the pros, for something like that.
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    In Alabama, rust grows pretty fast. I'd get it repaired ASAP, but don't be surprised if it comes back in a few years. Its VERY difficult to eliminate rust that has advanced that far. So to answer your question: the longer you wait to get it worked on the greater the chance it comes back. There are coatings that are supposed to chemically "freeze" rust and can be painted over. I couldn't say if they actually work.
  6. rjparker
    7,918
    4,680
    Get some touch up paint from the dealer (small bottle with brush) sand lightly on the rust and dab on the paint, maybe two coats, until the complete repair later.
  7. Air_Boss
    Air_Boss Senior Member
    3,940
    1,077
    New Yawk
    A chemical conversion coating will de-oxidize and inert the base metal, but you really want to clean it up first; abrade away the rust gouges and blend out the surrounding paint area, then apply the conversion coating, then clean the area with isopropyl alcohol wipes, allow it to air dry, then primer it, then apply color, then clear coat if applicable. That's how you get to $500-$700 professionally.
  8. Mendel Leisk
    38,649
    Yup, especially with their paint blending magic. They'll make it disappear, and stay gone.
  9. rjparker
    7,918
    4,680
    OP has a pretty substantial dent right over the roof joint, a particularly difficult detail to fix right. Generally good body shops will repaint the whole panel.
  10. Air_Boss
    3,940
    1,077
    New Yawk
    May have to drop the headliner to pop or dolly that back to spec from inside.
  11. Mendel Leisk
    38,649
    What our shop does, when you can't get around the back, is weld on these nail heads, in the dent. Then they get a grip on the nails and pull the dent out. Then they hit the nails sideways, breaks the weld, and fill/grind to finished surface.
  12. Air_Boss
    3,940
    1,077
    New Yawk
    That technique works well on tight, compound curves, too. .
  13. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    After going through the trouble of welding, and pulling the dent out, probably better to use a cutoff wheel to remove the nails instead of whacking it with a hammer.
  14. ehand88
    Birmingham, AL
    2014 Prius v wagon
    I went around to a few places yesterday and got some repair estimates. I'm looking at $1150 to $1400 for a full repair. I also asked one place how much it would cost to just sand out the rust and paint it - $400. The initial $700 estimate was just from a guy eyeballing it at a local dealership shop.
  15. rjparker
    7,918
    4,680
    I thought 700 was a good deal.
  16. Mendel Leisk
    38,649
    Maybe too good?
  17. Air_Boss
    3,940
    1,077
    New Yawk
    Worth the extra $1000 to pound out a dent you'll arguably put back in moving camping gear onto and off the roof rack?
  18. Mendel Leisk
    38,649
    A 2014? I would, but that's just me.
  19. ehand88
    Birmingham, AL
    2014 Prius v wagon
    This is more or less what I was weighing in my head. I will probably end up going with the guy who does the dealership's work who quoted ~$700. He comes pretty well recommended.
