2016 Shifter Light?
Discussion in 'Gen 4 Prius Main Forum' started by ATHiker, Jan 26, 2016.
  1. eric1234
    eric1234 Active Member
    391
    200
    Hamden, CT
    mine actually seems "fairly" bright (not that I have any objective measure - but it is as bright as the 2010, I'd say). In fact, I'd prefer it a bit less bright, as any light within the car works against the goal of enhanced vision of the light outside of the car...
    RCO likes this.
  2. krmcg
    2,592
    2,392
    Whittier, CA
    The light when I hold my hand up to it seems fairly bright, but as I lower my hand toward the shifter it loses brightness fast.
  3. Mendel Leisk
    40,991
    ^Damn physics!
    Geo Dude, RCO and krmcg like this.
  4. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    Time for a "Cree" replacement! ;)
    Oversplode likes this.
  5. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    You wouldn't want it much brighter - this is on all the time, after all (I imagine it comes on with the instrument panel lights), and you certainly wouldn't want something that affected night vision. If I block the light, it does make the shift lever harder to pick out, so I guess it does its job. Interestingly, it seems to faintly light the whole center console, making the white material a lot easier to understand. Now that I've finally noticed this, it's kinda useful - I no longer envy the Two's flat black center console.
    RCO likes this.
  6. ETP
    2,802
    1,170
    Auburdale FL
    Cup holder area?
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Yes, it would be nice if the shifter handle lit up... and also the radio knobs. (just for "looks")
    I wouldn't want that little spot light any brighter. It would be distracting, to me. I wonder if it was actually meant for the "phone well", and not the shift knob?
    Anywho, mine lights up the shifter console, the phone charger pad, and the first cup holder too.
    RCO and ETP like this.
  8. ETP
    2,802
    1,170
    Auburdale FL
    Critical item is the first cup holder.:LOL:got to have coffee.
    Mendel Leisk, RCO and bisco like this.
  9. Mo mo
    Mo mo New Member
    Irvine CA
    You turn on the light by turning on your headlights!!! It will light up the Park "P" from within and the gear shift from above.
  10. th3118
    th3118 Junior Member
    Mesa, AZ
    2022 Prius
    You can increase the brightness from above the shifter by increasing the brightness with the dimmer switch on the left side of dash. Even at max brightness, it’s not very bright.
