crazy audio!
Discussion in 'Gen 3 Prius Audio and Electronics' started by bvaughan, May 23, 2016.
  1. bvaughan
    bvaughan New Member
    memphis, tn
    When it gets near 80 degrees my entire audio system first gets scratchy, then goes out altogether. A nice cool night and the next morning it is back going until the midday sun and heat arrive.
    Anyone with advice on this?
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,036
    519
    Tucson, AZ
    2021 Prius
    Welcome to PC ! I can't comment directly on this Prius-specific malfunction, but I've had car audio components in the past that have behaved like that. Usually came down to a compromised capacitor that became heat-sensitive as a result. In this case I bench-checked the unit with a 12V power supply and when it malfunctioned I sprayed each capacitor in turn with non-conductive freeze spray for electronics. Found the culprit, removed, ordered, and replaced. More cost-effective than a complete replacement.
  3. CoolPrius
    CoolPrius Active Member
    218
    290
    86
    Virginia
    2018 Prius c
    I had a similar situation as AzWxGuy in a different car. The pioneer aftermarket radio would not work when temperatures dipped below 30. The manufacturer replaced a bad capacitor under warranty.
  4. bvaughan
    bvaughan New Member
    memphis, tn
    Thanks for the quick reply! I've also heard that it could be the amp since all functions, including the cd and phone go out. Thoughts?
