Engine coolant and oil loss
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Currahee, Apr 27, 2016.
  1. Currahee
    Currahee Member
    103
    34
    CT
    We have a 2010 Prius with ~120k miles and a supposed oil leak; about half a quart for the last 500 miles. Ongoing for some unknown period of time. I haven't seen any oil on the ground for the past week. Furthermore, the engine coolant is very low. The dealer believes the "seepage" is due to head gasket, which would cost $2400 to repair.
    This isn't my car (my gen 2 runs great), but it reminds me of my beloved 1996 Subaru which had to be let go because of an expensive head gasket and emissions failure. We expected the Toyota engine to last much longer. So far, the Prius hasn't thrown any check engine lights. Is this unusual? Any signs I can look for that might confirm the head gasket leak or suggest a less expensive diagnosis?
    I've included some pictures here:
    52,219
    welcome! actually, it's fairly common. if it's running well and getting good mpg's, just keep an eye on, and top up the oil. there are quite a few threads here if you want to do some research and educate yourself. all the best!(y)
    how are you checking the coolant?
  3. working1
    working1 Active Member
    121
    112
    Was the coolant replaced recently? At 120K it's past due. Just trying to eliminate air being trapped from a coolant change causing the low level.
  4. Currahee
    Currahee Member
    103
    34
    CT
    Just visually, in the overflow tank.
    AFAIK the coolant wasn't replaced recently, if ever. It looks brighter than my 2007, though, which is also up for a change. I had planned to take in to a trusted non-dealer to change the coolant and get a second opinion on the head gasket. Having just spent over $1000 to replaced the tires and rear brakes, however, we're a bit repair-weary. For the dealer to service all the fluids (coolants, transaxle, brake) would cost over $700.
    Glad to hear it's manageable, so we don't have a catastrophic failure to look forward to in a couple years?
  5. bisco
    52,219
    not likely. they say you need to check the coolant in the radiator.
  6. Currahee
    Currahee Member
    103
    34
    CT
    OK, I'll do that. Should I bother with oil additives for magical seal conditioning? I noticed there aren't any "high mileage" 0w-20 synthetics.
  7. bisco
    52,219
    idk, as i said, there's a lot of discussion in other threads. additives, what weight oil, dino vs syn, etc.
  8. JC91006
    JC91006 Senior Member
    16,802
    8,591
    There is nothing wrong with your car's head gasket. The car is just burning oil and you have to keep an eye on it. Top off the oil when needed.
    Prius burning oil is quite common as the miles get higher.....don't let those dealers scare you into giving them money for repairs not needed. You should however get all your coolant changed at 100k miles.
    Coast Cruiser likes this.
  9. douglasjre
    douglasjre Senior Member
    2,198
    731
    Null, NL
    Go to Mobil 1 0W-40 oil. 20 is too thin. It's no wonder the rings are wearing out on these things.
    dnaeye likes this.
  10. zoeboi954
    zoeboi954 Junior Member
    83
    22
    I am 100 percent certain it is your head gasket. I'm going through the same bull. From coolant lost and burning oil there a chance that you getting air/oil in coolant system which will break your water pump... happen to me. I even tried the liquid that you pour in the coolant to seal the gasket it worked for a while but the problems came back
  11. JC91006
    16,802
    8,591
    well your problem is pouring liquid into the coolant.....that's 100% guaranteed to plug up your car's cooling system. It is easy to spot coolant in your oil, just pull out your dipstick and look at it.
  12. zoeboi954
    83
    22
    I dont agree with using the it, but i poured the liquid in after my pump died and was replaced, my coolant system isn't clogged I'm still getting a flow but I still need to replace the head gasket
  13. trip1027
    trip1027 Member
    106
    27
    wyoming
    Hey I had same issue but it was going into my intake... I just changed the pcv valve and problem was fixed less then $6 for the part. Something to do with the air vacuum but yeah my 2010 had 136000 miles on it when it happened
    SM-N920V ?
  14. Currahee
    Currahee Member
    103
    34
    CT
    OK I'll look into replacing the PCV valve.
    There's no radiator cap on the gen 3 so I couldn't check the level there as recommended above. Doesn't seem to be any residue in the oil (see cap picture) but it's still confusing why the coolant level would be so low if it was just burning oil.
    Most likely we'll stick to the recommended oil since there isn't a consensus on how effective other weights are. If anything it would be sharing high mileage synthetic 5w-30 with the gen 2.
  15. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,717
    1,757
    Bay Area
    If you had a head gasket problem, your coolant will seep into the engine oil. To check if that is the problem, you can drain the oil and if it looks murky, then you have a blown head gasket. I wouldn't risk driving your vehicle with a blown head gasket as it can damage your engine as well. Good luck.
    nicoj36 likes this.
  16. Currahee
    Currahee Member
    103
    34
    CT
    I haven't noticed coolant loss since topping off the fluids last month, so if there is seepage it's not serious. The oil burn rate is about 1.5 qt per 3k miles. Bumping this thread to mention that I found a high-mileage 0w-20 offered by Valvoline. This is the only HM oil I can find at that weight, still not sure why. Will use it for topping off from now on.
  17. bisco
    52,219
    fingers crossed!(y)
  18. working1
    121
    112
    Assume this is the "Valvoline Full Synthetic with MaxLife Technology". I have found no place to buy this. It appears on their website, but, seems to be vaporware.
    0W-20 Motor Oil 5-Quart Part: 852399 UPC: 0-74130-01578-4
    0W-20 Motor Oil Quart Part: 852400 UPC: 0-74130-01581-4
    Any tips on where to get it would be great.
  19. Currahee
    Currahee Member
    103
    34
    CT
    #19 Currahee, May 25, 2016
    working1 likes this.
  20. working1
    121
    112
    Excellent info. Thanks. Too bad I got enough oil for the next 4 oil changes, but, this will be used after that. I should be at 150K by then.
