2001 Prius: Gunk in inverter coolant reservoir after adding pink coolant
Discussion in 'Generation 1 Prius Discussion' started by romanlutsk, May 22, 2016.
  1. romanlutsk
    romanlutsk Junior Member
    73
    Cupertino, CA
    2002 Prius
    Hello everyone,
    I was running a little low on the inverter coolant, so bought the pink Pentofrost A4 from Autozone and and topped it off (maybe half a cup)
    A few minutes later I noticed some gunk forming in the reservoir (that looked like white-ish lard) and reduced coolant flow but thought it was washed up from the other parts of the system.
    I let it stand overnight and in the morning noticed that the level was low again, so I added another cup. Now all the liquid in the reservoir looks like molasses:
    Shared album - Roman Zhovtulya - Google Photos
    Any ideas what's going on and what to do about it?
    Thanks!
  2. bwilson4web
    16,330
    1. Use a suction device to draw out a sample.
    2. Get the proper Toyota coolant
    3. Drain system and collect all that comes out
    4. Refill with Toyota coolant
    5. Send a sample of the 3d party, Toyota, and collected material to a lab, like R&G in Tampa Florida, and ask for an analysis
    There are somethings were it makes sense to hire an expert.
  3. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    The Amazon.com description:
    I don't think the Toyota pink fluid is a phosphated OAT but I am not sure. But it does not list it in the ingredients.
    I'd try to get as much out as possible before starting up.
    #3 wjtracy, May 22, 2016
    bwilson4web likes this.
  4. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    All good points - thanks a lot!
    I've drained the goo and currently flushing the system with distilled water. 4 gallons so far and the goo is still coming out :)
    Just picked the Toyota SLLC from the dealer and will fill it up once clean water comes out. Will post progress.
    DRACO, bwilson4web and wjtracy like this.
  5. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    Just take your time.
  6. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Ok, 4 drain/refills/bleedings later, having used 7 gallons of distilled water and spending over 4 hours, the catastrophe is averted and the goo is almost gone.
    The fluid movement in the reservoir is much more vigorous now than even before I added the wrong coolant. So, it's a positive outcome overall and a great learning experience. Now I can change inverter coolants with my eyes closed :)
    Here's a good thread with some key points for changing the fluid and bleeding the system as well:
    Changing Inverter Coolant Fluid. | PriusChat
    Again, thanks for all the help - couldn't have done it alone.
  7. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Good News, well, if I may, drive her for awhile and flush again to get the rest of the goop out.
  8. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Yes, I thought about it too. But at $25/gallon, the Toyota coolant is not exactly cheap. I flushed it with water 4 times before and it looks pretty clean so far. Will see - I might do it at the next oil change though.
  9. tochatihu
    tochatihu Senior Member
    9,850
    3,806
    Kunming Yunnan China
    2001 Prius
    Vigorous movement in the reservoir is a good thing :D
