So this is what happens when you run out of gas
Discussion in 'Gen 4 Prius Main Forum' started by ucla107, May 28, 2016.
  1. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Ran out of gas once in my '05 on an empty stretch of highway in the middle of nowhere. Was cruising at 51mpg and the low fuel warning came on a mere 8 miles before the dash lit up like a Christmas tree. Got two gallons from a wrecker and then filled up at a station that turned out to be less than five miles more down the road. Car was fine after that, no problems until a Mercedes driver totalled it years later.
  2. ETP
    2,802
    1,170
    Auburdale FL
    So next can of worms. Should we be driving bigger cars to be safe?
  3. bisco
    51,895
    or should nhtsa require larger cars to be smaller, with same height bumpers?
    ETP likes this.
  4. ETP
    2,802
    1,170
    Auburdale FL
    That's my vote but it will take awhile for that to happen. Escalade???
    Crew cab?
    Really like the Johnny cabbies in the movie Total Recall
  5. wrprice
    415
    308
    Houston, TX
    Four Touring
    Not to derail the thread much more... C250 (I think) vs '05 Prius in a rear end collision, the Prius kept us quite safe and without whiplash. uploadfromtaptalk1464464794523.jpg
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Way to go CC, a pioneer for new Prius owners and a new record for consecutive warning messages. :LOL: (y) ;)
    Debris ? in a new car ?
    bisco and ETP like this.
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    It's hard to admonish the OP when some veteran members ran their cars out intentionally (they will remain un-named - to protect the guilty) ;) .
    It's not a good idea to run a Prius of -any- generation out of fuel. It's probably worse re complaining by the cars systems with the newer generations. But it happens. No damage no foul. Carry on!
    As with most computer generated error messages, much comedy, little truth.
  8. bisco
    51,895
    and yet, we trust the obd reader to a fault.
  9. wrprice
    415
    308
    Houston, TX
    Four Touring
    Trust the OBDII port. Never, but never, question the engineer.
  10. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    First my car fuel bar flashes for me. Then, it chimes a warning to me. I have done this twice, not intentionally. When you drive a Prius, you don't need to fill up as often. I was use to going once a week. Now, its nearly 2 and a half weeks. I have to watch the gauge a lot more closely.
    Coast Cruiser and PriUncut like this.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    No admonishments needed, as I've said before, the Prius is unbreakable, unless you crash it or hack it.
  12. ETP
    2,802
    1,170
    Auburdale FL
    So is that like, "lets see what happens if I put my arm in front of a chain saw":ROFLMAO::LOL:
    Might check the low light near a gas station but that is it.
    Coast Cruiser likes this.
  13. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    True you can always spend on the side of the road out of gas and AC or heat. Its not rocket science to check gas gauge and get gas when it shows you are low.
  14. ucla107
    ucla107 Member
    98
    107
    Four Touring
    Didn't drive any differently during the last take. I drive the same stretch every day 112mi round trip and fill up at the same gas station, mostly with the same pump, yeah pretty boring, so I was "pretty sure" that I was gonna be able to make it to the gas station after work... Apparently not.
    The low fuel light came on about 5-7mi into my drive to work (I don't remember exactly where) so with that being about 85mi from where I usually fill up on the way home from work, I thought I was still in the "safe zone"
    Just earlier the month I was able to safely travel 551mi on 10.966 gal without running out... Trip computer said 52.6mpg and calculation was 50.2mpg
    This tank was just shy of 550 (549) when the trip computer said 51.6mpg and calculation was 48.2mpg
    I didn't pay attention to where the battery level was when it ran out but as soon as that "Hybrid System stopped steering power low" message popped up on the dash I pulled over to the side... I turned off the car and tried to start it back up and it wouldn't and the rest of the messages came on... After I refueled it then it's was all good... No messages, zip. But the battery was only at 2 bars and the engine was running to charge the battery so I'd assume that it pretty much stopped the car when it's at a low hybrid battery level but because there is no gas to run the ICE then it all stops
    Apparently after looking at other posts, the ICE would stop but you can still use the battery to drive for a period... I can't validate that since I was more in a panic mode lol
    bisco, Coast Cruiser and bwilson4web like this.
  15. bwilson4web
    16,201
    This is an important safety feature, the ability to use the traction battery to reach a safe place. If you feel like it, put a 1 gallon spare can in the car when you're getting close and let it run out of gas. Then document if you can the ability to travel 0.5 miles to a safe place to add the spare gallon.
    I never tried to measure the traction battery range when the engine is out of gas beyond 0.5 miles at 25-30 mph. This is an important safety fact and could help future, Prius 4 owners. Of course the 'hair on fire' folks will continue to complain but I've been married 40 years and complaints don't hurt. <GRINS>
    I was and remain personally very unhappy with the Gen-3 terrible indication of 'out of fuel.' The Gen-3 hides the fact until the traction battery is too low and then throws up a false "Power Steering" light. It still pisses me off but not enough to make an NHTSA report. Now it is moot.
    Since I bought a different car than a 2016 Prius on Friday, I won't be pursuing this unless I decide to replace our Gen-3 with another Prius. A future puzzle to figure out.
  16. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    ucla107, thanks for telling us about your experience. I think I will start refueling when the gas gauge gets down to the last bar. (I don't think I'll ever make it into the 700 mile club. ;))
    I use AAA Auto Club for emergencies, but I think we new buyers also have free "Toyota Road Service" for 2 years? Has anybody ever used that?
    I don't recall seeing the fuel bar flashing in my Gen4. That's a good feature you have. But I think I did hear one, barely audible chime, when the low-fuel message popped up on my screen.
    It would be really nice if the loud female Navigation voice I hear in my Prius, came over the speakers to advise me to get to a gas station.
    This is what I saw and heard when my low-fuel light came on...
    helmkera, ucla107 and bisco like this.
  17. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    On my gen3 I get consistently 6% error on mpg, about half of that if I consider the first click. Let's see what the error will be on the Gen4.
    PS: yes, some gas stations are at least cheating by 1-2%
    ETP likes this.
  18. wrprice
    415
    308
    Houston, TX
    Four Touring
    The one time I ran out it was at highway speed. I shut off A/C, put on the hazards, and drove at about 40 MPH (to stay below the MG1 RPM limit for EV drive in Gen2) and easily made it a mile or two down the road to the next exit. I even was able to stop, make a left, and travel just under another mile at slow speed on a county road hoping to find a filling station. There wasn't one and I stopped at zero bars on the HV battery display. If I hadn't exited, it turns out that maybe I could've coasted into one at the very next exit.
    Either way, it was very nice to have several minutes of locomotive power and options even though the ICE was unavailable due to my own stupidity.
    ETP, bisco and bwilson4web like this.
  19. ETP
    2,802
    1,170
    Auburdale FL
    Don't you remember your mom nagging your dad, "you need to stop for gas". Your dad said, "no we have got plenty".
  20. wrprice
    415
    308
    Houston, TX
    Four Touring
    Back then, Dad was driving a Ford Econoline with two tanks, so... flip a switch and he really did have plenty. :)
