Trouble editing first post
Discussion in 'PriusChat Website Questions' started by bwilson4web, May 30, 2016.
  1. bwilson4web
    16,202
    I tried three browsers trying to edit: Why the BMW i3-REx | PriusChat
    • edit screen appear normal
    • 'submit' shows progress but it times out
    • rebooting computer has no effect
    I was trying to add some metrics to the first post with the predicted performance. As a workaround, I added a new post to the end of the thread with the metrics. This is not a 'big deal' other than it dilutes what we know in the body of the thread. I am OK with this but suspect others may miss the new details.
    Not a 'hair on fire' but just 'this is what I'm seeing'.
    Trying to add a line after a second post in the thread.
    ETP likes this.
  2. Mendel Leisk
    41,402
    @ETP was having a similar problem I think, couldn't edit his intial posting, about his new 2016.
    I'm having a problem doing ANY posting, typed this last bit while stalled. :(
    ETP, bisco and bwilson4web like this.
  3. bwilson4web
    16,202
    Hummm, I appreciate the follow-up post as it allowed me to check if adding postings to a thread triggered the effect. It suggests there may be something about the content that triggers the symptom.
    ETP likes this.
  4. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    There has been a problem with the site for a while now. I too have had problems making edits, and then posting said edits. Same problem, times out before posting.
    Also have problems submitting post's on thread's such as this one. It happens sporadically, can't explain it other than that.
    bwilson4web likes this.
  5. bwilson4web
    16,202
    It might be interesting if a moderator could replicate the first-post, editing problem. I'd seen the intermittent ones in the past. But we may have an example that the moderator team can use to figure out what is going on:
    Problem post: "Why the BMW i3-REx | PriusChat"
    I 'reported' this post to the moderator team to give them a 'heads up.'
    #5 bwilson4web, May 30, 2016
  6. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    There are ongoing issues, it is affecting moderators and their functions as well. We've told Danny, that's all we can do.
    bwilson4web, Mendel Leisk and bisco like this.
  7. bisco
    51,895
    it was good for about a week or so.
    ETP likes this.
  8. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It seems to randomly affect certain threads for no/some reason. It seems a thread that an OP cannot edit the title on cannot also be moderated. If I try and move bobs linked to thread about the i3rex, it hangs up and eventually gets the Error 502 bad gateway message.
    Its done this same thing in the past, many times actually. It would go away but eventually always comes back. Its becoming quite the pain at times...
    ETP likes this.
  9. bisco
    51,895
    you are a very patient person. these 6 words took 29 seconds to post.
    ETP and Mendel Leisk like this.
  10. ETP
    2,802
    1,170
    Auburdale FL
    Paradox= two docs in the same room
    BTW editing titles issue has come back. It acts like it is doing it then comes back with a Prius chat website issue warning page in Win 10 both IE and Edge.
    priuschat.com
    Host
    Error
    Could be the PICs in the post. When it was really bad I could not delete the PICs in the first post. Huummm.
    I was able to add a poll but could not edit the title.
    Looks like the site is smoken this morning.
