What's the best way of running the Air Conditioner
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Dimitrij, Jun 8, 2016.
  1. Dimitrij
    Dimitrij Active Member
    405
    202
    Virginia
    Greetings
    For some reason, I haven't found any previous discussions that would answer my question. Which is, "What's the best way of running the air conditioner economically". To re-phrase: if I want to maintain 74-76F inside, should I use LO temperature setting + LO fan speed, or set the temperature at where I want it and rely on automation to find the best algorithm?
    It's a 2014 C :)
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Very simple. Set on AUTO. Set the temperature you want. This is the best way to get the temperature you want. If you want to be more economical, use ECO mode and the car will adjust for efficiency.
  3. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    Yep - That's about it...
  4. Dimitrij
    405
    202
    Virginia
    Thank you both .. this probably means that the compressor is the variable speed type, so it just runs faster or more slowly when I set the AC to make the air colder or warmer (unlike the conventional, engine-driven compressor AC system that mixes cold- and warm air to achieve the desired temperature).
  5. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    We also tend to feel A/C serves the alternative purpose of cooling the HV batt so it's a good thing
  6. Mendel Leisk
    41,310
    I rarely use the AC for cooling, but when I do:
    1. Set the ventilation system to AUTO, and AC button depressed.
    2. Set ambient temperature high enough that the fan doesn't race. I try to avoid fan speed going higher than hallway.Typically that'll take a temp setting around 30C (86F).
    3. As the cabin cools and fan speed starts to drop, lower the set temp., aiming for a target temp around 24~25C (75~77F).
  7. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I agree that the AUTO setting works quite well. If I get into the car when it's very hot or very cold, I'll sometime crank the temperature dial all the way over to LO or HI to get the maximum amount of cooling or heating as fast as possible - but for the A/C I rarely need to do this for more than 15 to 30 seconds. After that I set it to a specific temperature and let it do its thing. I'll occasionally change the temperature setting if, for example, I start driving in a different direction and the sun is now shining directly on me through the window, but generally speaking I just leave it and it works very well.
    I generally leave the HVAC system set to "recirculate" on the theory that it doesn't have to work as hard when the air going into the system is near the same temperature as the air coming out of the system. It also helps to keep smelly exhaust out of the car (although even in recirc mode I believe the system still blends in a bit of outside air for safety reasons). When you do that the A/C runs at a pretty low level to dehumidify the air - if you turn off the A/C you'll notice the windows starting to fog up after several minutes. But that level of A/C doesn't seem to have any serious impact on fuel economy - mine is still comfortably better than the EPA rating (which itself is an awfully good number) so I'm happy.
    milkman44 likes this.
  8. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    Why turn off AC?
    iPhone ?
  9. bisco
    51,840
    i turn my fan on, then press the a/c on and off as desired, while continually monkeying around with fan speed and vent direction. what could be more efficient than that?:cool:
    4rpr15 likes this.
  10. Mendel Leisk
    41,310
    Air Conditionng use lowers your mpg. Constant use can lead to mould getting a foothold in the ventilation system.
    Monitoring battery temps, I've seen no temp drop with AC use. This seems largely urban myth.
    Mainly, I don't relish driving in a "personal climate bubble", at least not all the time. On a warm day, I'll just roll the windows down a bit, or all the way, depending on speed.
    Petridish38, KK6PD and 4rpr15 like this.
  11. bisco
    51,840
    try that in vegas in july.;)
  12. breakfast
    breakfast Active Member
    266
    199
    Exactly. What might work in mild Vancouver, BC (where Mendel lives) might not in muggy, hot Virginia (where the original poster lives). As others have said, I think running the AC is a smart thing to do in a Prius in terms of keeping the battery cool, and is a minor hit on MPG. lIf you can keep it at the higher range (say 74 degrees F), the MPG hit is further lessened.
  13. Mendel Leisk
    41,310
    I was responding to a question posed in #8, off-topic, I agree. What I said in #6 I've found to be the most effective way to use AC.
  14. mmmodem
    2,732
    1,703
    Bay Area, CA
    I read somewhere that the way to mitigate this is to turn off AC and run just the fan prior to stopping the car. For my CA temperatures 1 block or 10 seconds prior to my destination is enough to not get entirely too uncomfortable. It is said that this prevents condensation building up in the air pathways due to temperature difference. I've been doing this for years and it's helped.
    Merkey and Mendel Leisk like this.
  15. Mendel Leisk
    41,310
    Yeah, I find in practice it takes about 10 minutes, at least for the window fogging to abate.
    The AC radiator (apologies for not recalling its official name) is akin to an icy glass of water on a hot/humid day, coated in condensation. Once the AC's shut down and the fins return to ambient temp, with myriad fins it takes some time for all moisture to disperse and/or find it's way out the drain tube.
  16. bisco
    51,840
    probably depends on the climate you live in. we've never had a/c problems in 45 years of driving.
  17. mmmodem
    2,732
    1,703
    Bay Area, CA
    10 minutes? I'll take the smell. 1st world problem I guess.
  18. Sean Nelson
    421
    182
    The radiator-like part inside the dash that cools the air flowing through the HVAC system is called the "evaporator". That's because the refrigerant enters the evaporator as a liquid and leaves as a gas, cooling down dramatically in the process. It's like "canned air" - if you spray one of those cans for several seconds the can will get quite cold and can even get frost forming on its surface.
  19. bisco
    51,840
    why is this not an issue with central a/c?
  20. Sean Nelson
    421
    182
    It can be - see Legionaire's Disease. Here's a story about an outbreak in New York last year that infected 100 people.
    As far as I know automotive A/C systems have never been associated with this disease.
